three positec vrdm 564/50 motors 5 phase and a 3 axis 5 phase controller
hello please
3 positec 5 phase mini motors and a pac controller
3x little 5 phase motors - they dont like the mach i think as they are a 10 wire motor
about 45mm long with a 60mm bolt doofer - so not like nema 23 which is 57mm
erm
the controller is a three axis affair with cards that kind of plug in
again 5 phase
ran from a 24v psu
thanks
erm has a breakout board of the rs232 variety
a power card
50 quid the lot
i will have another one next weekend too
plus me thinks a 2 axis foam cutting machine, smallish
very nice
located in the fulham = i.e. collection only
postage is £150
i am cutting the cables from the motors and using the rs232 ends to my new drives and motors
i just bought tint nema 23's 8 wire and some little drivers - why I don't know - or I know I can get it to work.
this maybe really easy for you
came from a high end mini mill
ta
Re: three positec vrdm 564/50 motors 5 phase and a 3 axis 5 phase controller
Pics of the three phase motors/controller ?
5 Attachment(s)
Attachment 31700
Attachment 31701
Attachment 31702
Attachment 31704
Attachment 31703
3 motors no cables - i am using them on my new motors and drivers
i could leave it all ready to run IF you vcan work out the inputs into the rs232 port on the controller and sell you the unmessed with cabling
the rs232 in is only 11 pins so you can work out the pulses to that and the torch controll you are golden really
I can - or do not wish to bother = i am cutting off the cables and using the rs232 ends to my new drivers - or I could just get new wire and charge you more money
then you have a sweet little 5 phase machine 500 pulses per rev
i bet you could simply plug it into a rs232 port on a computer and run mach through it.
i have just picked up the other machine
its 4 axis
similar looking controller and drive set up
with older but the same motors
circa i think 1998
will do a deal if you buy the lot
thanks
