    Evening Chaps,
    I wondered if anyone could help me with the correct size capacitor for my PSU. The calculations come out to 11,764 uF and the voltage is 68V (allowing an additional 20% as per Gecko guide =88v) I've found a 10,000uF 100v capacitor on eBay, is this close enough or should I use three 4,700uF 100v and wire in parallel?
    Many thanks
    Mike
    Lives in Marple Stockport, United Kingdom. Last Activity: 16 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 3,348. Received thanks 620 times, giving thanks to others 90 times. Made a monetary donation to the upkeep of the community. Is a beta tester for Machinists Network features.
    Personally I would use three as you say because they are generally cheaper. Something like this :https://www.rapidonline.com/samwha-h...acitor-11-3121
    A piece of advice about capacitors:
    Don't buy a capacitor from non reputable seller, especially ebay.
    Too many reasons to explain here but in short : China, not genuine, quality, NOS etc.
    Buy from Mouser or RS online, i don't know about Rapid online, but i assume as Clive pointed you there it should be good. Buy a brand capacitor- Panasonic,etc. Look for rating 85C or even better 105C rated
    Plus i wouldn't save a dollar from a capacitor. A good normal one 85C is rated 2000-3000h at the temperature rating. A better one exact value, not a stack of cheaper smaller ones, that is meant especially for computer and other power supplies could be rated 105C and 20 000h . So its up to you if you will save a $ or 2 from your power supply. Questions to ask yourself: how many hours per day the machine will work, how many years you expect it to last, do you have time later to stop production and investigate eventual problems.
    If it was me i would buy a single screw terminal can type capacitor, meant to be there, less space, easy to exchange.
  4. The Following User Says Thank You to Boyan Silyavski For This Useful Post:
  5. #4
    Don't get paranoid with Cap quality or go OTT it's not that critial.
    Go with 3 x 4700Uf. They are cheaper and easier to find and provide less ripple than one large Cap. Even the cheap Ebay ones are ok provided you size them correctly. Give them plenty of overhead on voltage and you won't have problem.
    I've built probably 100 + and just about every one used 3 x 4700 and never had any issues, Zero failure (Unless I cock up polarity.!!) The PSU running my Own machine is nearly 10yrs old and used Cheap Ebay caps, It's still going strong and as runs for 10hrs day most days.
    I buy mine from Farnell.
  6. #5
    You can buy cheap Chinese capacitors from China, or you can buy expensive Chinese capacitors from RS or Farnell. It is your choice depending on your perception of quality and service.
  7. #6
    One large cap just means there is just one large component which, when it fails, will render your PSU broken.
    Provided the conductor area of the connecting bus is large and it's length is short there is no reason not to use several smaller caps in parallel, but buy branded quality from a reputable supplier,
    - Nick
  8. #7
    I am partly retracting my former statement in the light of this article http://www.hardwaresecrets.com/how-t...ic-capacitors/
    Rob
  9. The Following User Says Thank You to cropwell For This Useful Post:
  10. #8
    Rob at our time of life if they last 10 years it's a bonus
  11. #9
    Ten more yrs.!!! . . . . Now't like being optimistic.
  12. #10
    Its absolutely not like you present it.
  1. Power supply
    By racerbear02 in forum Laser Machines & Building
    Last Post: 13-09-2015, 09:27 AM
  2. FOR SALE: power supply
    Last Post: 14-09-2014, 03:19 PM
  3. Replies: 0
  4. FOR SALE: 50V 20A Power supply
    Last Post: 30-05-2011, 11:01 PM
  5. power supply
    By hitmythumb in forum General Electronics
    Last Post: 21-06-2009, 10:27 AM
