Thread: How to get this finish?
01-07-2016 #2
The type of finish you are after is attainable but only with considerable time and money. Normal household paints or automotive rattle cans just do not cut it. Only one way I have found to get a decent finish on MDF.
Sand well with fine grit sanding wheel.
Apply MDF sealer,
Sand lightly again.
Use a 2 pack Hi-build primer.
Light sand with 600 grit paper.
2 or 3 coats of 2 pack finish colour,
2 or more coats of clear coat.
If you want to go this route you will need a good quality air fed spray gun, a spray booth and good PPE because the 2 pack is nasty stuff if you inhale it.
Commercial furniture spray paints are available that can do the job much easier but are expensive and you have to buy at least 100 litres at a time.
Good luckLast edited by alboy; 01-07-2016 at 10:23 PM.
The Following User Says Thank You to alboy For This Useful Post:
01-07-2016 #3
Im not after perfect juaf after a good finish
Thanks for all thd advice
02-07-2016 #4
How to get this finish..?
By Wal in forum Metal Finishing TechniquesReplies: 15Last Post: 02-02-2017, 11:08 PM -
Smooth finish with v bit on mdf
By Skydeals in forum General DiscussionReplies: 7Last Post: 16-10-2015, 10:28 PM -
MDF.. More or less teeth/flutes for a better finish ?
By Nthkentman in forum Woodwork DiscussionReplies: 5Last Post: 22-11-2014, 12:42 PM -
Aluminum finish
By Boyan Silyavski in forum Metal Finishing TechniquesReplies: 3Last Post: 07-09-2014, 07:32 PM -
Better finish
By luke11cnc in forum Wood Finishing Tips & TricksReplies: 20Last Post: 27-03-2012, 11:25 PM
