    many thanks
    so whats a good wood to use then as im well aware mdf is poo. mdf just happens to be cheap and you can buy in large sheets
    MDF isn't easy to get the sort of finish you require, as mentioned it first needs to be sealed, then rubbed down ect, very labour intensive. i have used a product called eposeal, it's a two part epoxy and very thin but when dry it can be rubbed down and should be sealed(used it to seal some Iroko windows that had water penetration)
    Mike
    http://www.ebay.co.uk/itm/Gurit-SP30...EAAOSw~FNUaR5p
    Now that's the question?
    I dont have a CNC so have to do my woodworking using router/spindle the advantage with CNC is you can take off very small cuts using high feed rates and i believe this vastly reduces breakout. If you don't want to make them out of acrylic i think i would try some quality beech ply, but that's only a guess.
    Mike
    Nope. Wood tears and chips just as easily on a CNC as it does with your hands. Sometimes even more.
    The harder it is, the better the finish will probably be.
    You can get a good finish on MDF, if you seal it with epoxy, and sand until glass smooth.
    Gerry
    UCCNC 2022 Screenset
    Mach3 2010 Screenset
    Link me to some suitable epoxy?
    West System or similar.
    Gerry
    Commercial finishing processes rarely involve much manual work, if you use a self levelling primer after sealing you will have to sand rough areas after sealing but you won't need them perfectly smooth, experimentation will determine how smooth you need to go to achieve what you need ;-)
    I've achieved good finishes on wood sealed with an alcohol based automotive sealer, U-Pol's version of this is Barcoat, others are available. Snother option if you want to do more sanding is to use a Polyester based spray filler, U-Pol's version of this is Reface, it sands very easily and doesn't clog paper like hand mixed polyester fillers,
    - Nick
    You could try a shellac based sealer like Rustins Sanding Sealer. At least it dries quickly.
    ok lots of suggestions thanks.
    just to give a bit of context, I want to get a really good finish on this like this. its machines from mdf, due to the complex nature sanding is not welcome
    so with this stuff, put it first? then spray what ever colour over the top?
    http://www.ebay.co.uk/itm/U-pol-Barc...AAAOSwBLlU1gcf
    this suggests lots of sanding
    http://www.ebay.co.uk/itm/Rustins-SA...IAAOSw3YNXbkca
  1. How to get this finish..?
    By Wal in forum Metal Finishing Techniques
    Last Post: 02-02-2017, 11:08 PM
  2. Smooth finish with v bit on mdf
    By Skydeals in forum General Discussion
    Last Post: 16-10-2015, 10:28 PM
  3. MDF.. More or less teeth/flutes for a better finish ?
    By Nthkentman in forum Woodwork Discussion
    Last Post: 22-11-2014, 12:42 PM
  4. Aluminum finish
    By Boyan Silyavski in forum Metal Finishing Techniques
    Last Post: 07-09-2014, 07:32 PM
  5. Better finish
    By luke11cnc in forum Wood Finishing Tips & Tricks
    Last Post: 27-03-2012, 11:25 PM
