Thread: How to get this finish?
Commercial finishing processes rarely involve much manual work, if you use a self levelling primer after sealing you will have to sand rough areas after sealing but you won't need them perfectly smooth, experimentation will determine how smooth you need to go to achieve what you need ;-)
I've achieved good finishes on wood sealed with an alcohol based automotive sealer, U-Pol's version of this is Barcoat, others are available. Snother option if you want to do more sanding is to use a Polyester based spray filler, U-Pol's version of this is Reface, it sands very easily and doesn't clog paper like hand mixed polyester fillers,
- NickLast edited by magicniner; 01-07-2016 at 06:41 PM.
01-07-2016 #2
You could try a shellac based sealer like Rustins Sanding Sealer. At least it dries quickly.
01-07-2016 #3
ok lots of suggestions thanks.
just to give a bit of context, I want to get a really good finish on this like this. its machines from mdf, due to the complex nature sanding is not welcome
so with this stuff, put it first? then spray what ever colour over the top?
http://www.ebay.co.uk/itm/U-pol-Barc...AAAOSwBLlU1gcf
this suggests lots of sanding
http://www.ebay.co.uk/itm/Rustins-SA...IAAOSw3YNXbkca
01-07-2016 #4
The reasonably fine "engraved" features will tend to fill up with anything that might help cover rough surfaces.
The example you asked about has no fine surface detail, most likely for this reason.
You could cut the part leaving material for a fine finish path with a ball nose cutter on the detail and seal it with cyanoacrylate before the finishing cut,
- NickLast edited by magicniner; 01-07-2016 at 08:21 PM.
The Following User Says Thank You to magicniner For This Useful Post:
01-07-2016 #5
How to get this finish..?
By Wal in forum Metal Finishing TechniquesReplies: 15Last Post: 02-02-2017, 11:08 PM -
Smooth finish with v bit on mdf
By Skydeals in forum General DiscussionReplies: 7Last Post: 16-10-2015, 10:28 PM -
MDF.. More or less teeth/flutes for a better finish ?
By Nthkentman in forum Woodwork DiscussionReplies: 5Last Post: 22-11-2014, 12:42 PM -
Aluminum finish
By Boyan Silyavski in forum Metal Finishing TechniquesReplies: 3Last Post: 07-09-2014, 07:32 PM -
Better finish
By luke11cnc in forum Wood Finishing Tips & TricksReplies: 20Last Post: 27-03-2012, 11:25 PM
