Thread: How to get this finish?
The reasonably fine "engraved" features will tend to fill up with anything that might help cover rough surfaces.
The example you asked about has no fine surface detail, most likely for this reason.
You could cut the part leaving material for a fine finish path with a ball nose cutter on the detail and seal it with cyanoacrylate before the finishing cut,
- NickLast edited by magicniner; 01-07-2016 at 08:21 PM.
The Following User Says Thank You to magicniner For This Useful Post:
01-07-2016 #2
How to get this finish..?
By Wal in forum Metal Finishing TechniquesReplies: 15Last Post: 02-02-2017, 11:08 PM -
Smooth finish with v bit on mdf
By Skydeals in forum General DiscussionReplies: 7Last Post: 16-10-2015, 10:28 PM -
MDF.. More or less teeth/flutes for a better finish ?
By Nthkentman in forum Woodwork DiscussionReplies: 5Last Post: 22-11-2014, 12:42 PM -
Aluminum finish
By Boyan Silyavski in forum Metal Finishing TechniquesReplies: 3Last Post: 07-09-2014, 07:32 PM -
Better finish
By luke11cnc in forum Wood Finishing Tips & TricksReplies: 20Last Post: 27-03-2012, 11:25 PM
