    Afternoon all,
    Can anybody make a recommendation on the wire they use to to extend stepper motors. I'm using NEMA 34 86HS115-4208, wired in series drawing 3A at 70v. What gauge of wire would you use, does it need to be screened?
    Many thanks
    Mike
    Lives in Marple Stockport, United Kingdom. Last Activity: 14 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 3,348. Received thanks 620 times, giving thanks to others 90 times. Made a monetary donation to the upkeep of the community. Is a beta tester for Machinists Network features.
    Quote Originally Posted by RocketBoy View Post
    Afternoon all,
    Many thanks
    Mike
    How about CY cable 3A is nothing so 1mm or 1.5 mm will do.
    It is always a good idea to use the screen but ground it at one end at the star point in the control box.
    Edit: is there a reason for you to use a series connection instead of parallel ?
    Thanks for the reply Clive, appreciate it. I was tempted by series so the motors run cooler, the machine I'm refitting is a Denford Triac so didn't think I would need the extra speed of parallel. Very new to all this so would appreciate any advice. The kind of work I will be undertaking is model engine parts so mainly Alu, Brass and Steel.
    Mike
    Your thinking in this case is correct and for Mill then Series will be best connection because it will provide more torque lower down the RPM curve. But this will drop fast as the rpm rise. However you have half decent amount of volts at 70 so will be fine for Mill.
    Use 1.5mm CY cable for these motors. Shield just the Control box side like Clive suggested.
  1. How to wire the enable pin on a stepper drive?
    By cncJim in forum General Electronics
    Last Post: 01-01-2016, 05:10 PM
  2. What gauge wire for motors and drivers etc?
    By glynster in forum Gantry/Router Machines & Building
    Last Post: 01-03-2015, 01:40 PM
  3. How do I wire a stepper driver to a stepper motor?
    By swood1 in forum Stepper & Servo Motors
    Last Post: 21-09-2014, 05:40 PM
  4. Replies: 0
    Last Post: 22-06-2014, 01:59 PM
  5. Replies: 2
    Last Post: 12-06-2013, 01:04 PM
