Page 1 of 3 123 LastLast
    Not worked with carbon fibre before but some general Speed Feed and DOC will help, so if anybody's used this material before then any help is much appreciated.
    It's pre peg 3k 100% carbon
    At the minute I'm only cutting 0.25 thick carbon, but soon I'll be cutting 4mm, the cutter I've been using is a coated carbide 3 flute 2mm bit.
    Cheers.
    Now the proud owner of my own personal CNC machine happy days.
    I was recommended burr style bits for thin work, and to prevent delaminatin on both upper and lower surface compression cutters for thicker stuff.
    I seem to remember I found the information for feeds & speeds on the cutter manufacturer's site,n
    - Nick
    Cheers Nick I will check those out
    I have never cut but should be similar to fibreglass. Take care of the stick out as this severely could change things. I calculated all based on 20mm/ the tool shows 20mm from collet/
    Hope that helps
    Cheers boyan that does help
    Ended up downloading an app came back with this info
    Well thought I'd update this thread just in case somebody needs some info.
    I've cut 12 plates of carbon 293x129x4 and done a few various parts from the plate.
    Had a few trail and errors with cutters but found a cutter that works a treat and just 55p yes 55 pence, once they have done 1 plate they go in the bin.
    DOC I've been doing was .5 mostly cutting 2mm WOC at 24k
    Dean,
    That looks good, how's the edge finish?
    If you have a play with single flute carbide and can get them to work for you then sharpening is very easy, although you'll need magnification and a diamond wheel they can be ground offhand,
    Regards,
    Nick
    Cheers Nick I'm impressed with the out come, and doing this in ones garage compared to proper company's mine are and not been big headed are better.
    TBH Nick the edge is fine no delam or nothing, I use what I thinks called a corn cutter.
    The chassis plate needs a finish pass round the profile of the chassis plate, that's the big part in the pic only because a few bits are needed to be spot on.
    But it does leave a tinny lip on the carbon and most would not bother TBH but a simple rub round the edge with some 1000 wet and dry removes it, or a simple deburr in a matter of seconds.
    But the cutters I use Nick it's pointless even trying to regrind them mate, I can't even add cutter cost to parts theirs £120 of parts in the pic VS a 55 pence cutter the end mills are free :)
    Lives in Marple Stockport, United Kingdom. Last Activity: 15 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 3,348. Received thanks 620 times, giving thanks to others 90 times. Made a monetary donation to the upkeep of the community. Is a beta tester for Machinists Network features.
    Dean
    Would you be happy to share a link to the cutters. Nice work by the way.
    Sure Clive
    eBay item number 221965675192 don't let the Chinese put you off they came in around 6-8 days, and I'd bought 1 cutter from the UK and snapped in 55 seconds using the same speeds and feeds.
  1. RFQ: Carbon Fibre Plate Cut (2/2.5/3mm)
    By add1ct3dd in forum Projects, Jobs & Requests
    Last Post: 24-03-2016, 06:01 PM
  2. Replies: 1
    Last Post: 05-08-2015, 11:41 PM
  3. FOR SALE: Carbon Fibre Sheet 2mm (all carbon 3k)
    By richie00boy in forum Items For Sale
    Last Post: 27-02-2015, 08:44 PM
  4. Carbon Fibre Sheet
    By richie00boy in forum Marketplace Discussion
    Last Post: 12-01-2013, 07:46 PM
  5. Cutting Carbon Fibre
    By Tenson in forum Machine Discussion
    Last Post: 18-05-2012, 02:21 AM
