Hi all,
I've been using my cnc routerfor the last two years for mainly drilling holes for shelf peg holes and hinge holes for kitchen cupboards.
I also use it for cutting various curves and L shapes on corner cupboards.
I have a 2kw spindle and up until now i've been using a twin flute 1/2 inch 50mm straight cutter as they're cheap
The material used is 18mmMFC (melamine faced chipboard) and my cnc can only currently cut 2metres a minute
I've just bought a single flute compression spiral 1'2 shank Onsrud solid carbide cutter
So, given that the feed rate is that slow, What speed do you think I should set my spindle to run at ?
Thanks in advance
