    Lives in East Lothian, United Kingdom. Last Activity: 10 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 2,992. Received thanks 376 times, giving thanks to others 9 times.
    With a KFlop & Kanalog it's possible to use both +/-10V and step/dir, however to use the step/dir outputs you have to sacrifice Kanalog encoder inputs.
    Moray can you Mix n match or is it one or tuther..?
    Mix and match.
    There are 8 encoder channels (actually 16 differential inputs on the Kanalog - they're not solely for encoder inputs), which at KFlop level means 16 inputs, but those 16 inputs are actually general purpose IOs which also provide the Step/Dir outputs.
    4 of the encoder channels go through a separate RJ45 (Ethernet style connector) cable to the Kanalog, with the other 4 being in amongst the main 26pin ribbon cable with all the other signals. If you only need 4 encoders, you can simply make up your own cable to take 4 sets of Step/Dir signals from the RJ45 connector on the KFlop. Otherwise you have to start splitting cables depending on how many encoders and Step/Dir signals you need.
    Mix and match.
    Just looked at the manual because was curious and got to say that's one of the best most comprehensive manuals I've ever seen.
  1. Brushless DC Motor - Mach3 Compatible - Opinions?
    By smartbusa in forum Brushless Spindles & Motors
    Last Post: 23-12-2015, 11:42 AM
  2. servo motors questions
    By paulus.v in forum Stepper & Servo Motors
    Last Post: 27-07-2015, 10:31 AM
  3. help with servo motors Please.
    By ramsbury in forum Stepper & Servo Motors
    Last Post: 18-02-2014, 04:59 PM
  4. Bridgeport boss stepper motors
    By speedhound in forum Stepper & Servo Motors
    Last Post: 12-12-2010, 08:54 PM
