Thread: End Mill Height/Offset Setting
05-07-2016 #4
I'm with you better now, the only "dumb" suggestion I've got then is to have the holders setup in pairs, pre configured to the right offsets so you can just swap them when need be...
But as you say the scenario doesn't lend well to this...sorry.
Edit: Could you not make up a tool jig/block that registers from a face on the holder, that also has a register for the bottom of any cutter and would give the offset of 18.45 ? You know so it could be used as some kind of custom gauge block?
.MeLast edited by Lee Roberts; 05-07-2016 at 01:16 PM.
Mach4 in production run G52 offset with Sub
By Lee Roberts in forum Artsoft Mach (3 & 4)Replies: 8Last Post: 25-08-2014, 11:53 PM -
DXF with tool offset
By Cube3 in forum CAD & CAM SoftwareReplies: 4Last Post: 25-03-2014, 10:54 PM -
Tool Height Setting Probe - Mach3 - solution
By HiltonSteve in forum Tool & Tooling TechnologyReplies: 18Last Post: 12-11-2013, 06:23 PM -
Problem with height setting in artcam express.
By don_jarr in forum ArtcamReplies: 4Last Post: 07-11-2011, 03:26 AM -
Setting Z height with an ER32 collet
By Robin Hewitt in forum Machine DiscussionReplies: 0Last Post: 27-03-2010, 09:16 PM
