Thread: End Mill Height/Offset Setting
05-07-2016 #3
Thanks Lee. I am using boxford software and the tool offsets from the holder need to be setup before hand so I don't think I can use this method?
I have a number of quick change collets and if a tool breaks or needs changing I need to be able to quickly and accurately be able to place the new tool at the correct height.
e.g. Tool 1 has a z offset (from the easy change holder) set to 18.45mm so if it needs replacing I need a method to set the new tool to that offset in the holder.
JimLast edited by cncJim; 05-07-2016 at 12:14 PM.
Mach4 in production run G52 offset with Sub
By Lee Roberts in forum Artsoft Mach (3 & 4)Replies: 8Last Post: 25-08-2014, 11:53 PM -
DXF with tool offset
By Cube3 in forum CAD & CAM SoftwareReplies: 4Last Post: 25-03-2014, 10:54 PM -
Tool Height Setting Probe - Mach3 - solution
By HiltonSteve in forum Tool & Tooling TechnologyReplies: 18Last Post: 12-11-2013, 06:23 PM -
Problem with height setting in artcam express.
By don_jarr in forum ArtcamReplies: 4Last Post: 07-11-2011, 03:26 AM -
Setting Z height with an ER32 collet
By Robin Hewitt in forum Machine DiscussionReplies: 0Last Post: 27-03-2010, 09:16 PM
