05-07-2016 #1
Afternoon all,
Can anybody make a recommendation on the wire they use to to extend stepper motors. I'm using NEMA 34 86HS115-4208, wired in series drawing 3A at 70v. What gauge of wire would you use, does it need to be screened?
Many thanks
Mike
05-07-2016 #2
05-07-2016 #3
Thanks for the reply Clive, appreciate it. I was tempted by series so the motors run cooler, the machine I'm refitting is a Denford Triac so didn't think I would need the extra speed of parallel. Very new to all this so would appreciate any advice. The kind of work I will be undertaking is model engine parts so mainly Alu, Brass and Steel.
Mike
05-07-2016 #4
Your thinking in this case is correct and for Mill then Series will be best connection because it will provide more torque lower down the RPM curve. But this will drop fast as the rpm rise. However you have half decent amount of volts at 70 so will be fine for Mill.
Use 1.5mm CY cable for these motors. Shield just the Control box side like Clive suggested.
How to wire the enable pin on a stepper drive?
By cncJim in forum General ElectronicsReplies: 8Last Post: 01-01-2016, 05:10 PM -
What gauge wire for motors and drivers etc?
By glynster in forum Gantry/Router Machines & BuildingReplies: 8Last Post: 01-03-2015, 01:40 PM -
How do I wire a stepper driver to a stepper motor?
By swood1 in forum Stepper & Servo MotorsReplies: 7Last Post: 21-09-2014, 05:40 PM -
FOR SALE: 3 nema23 sanyo 3a 6.35 shaft 4 wire motors - 3 3a 24v 6560 drivers - 24v 15a psu £100
By nobby in forum Items For SaleReplies: 0Last Post: 22-06-2014, 01:59 PM -
nema 23's wire colours for bi-polar parallel, can you check this is correct please
By nobby in forum Stepper & Servo MotorsReplies: 2Last Post: 12-06-2013, 01:04 PM
