Thread: Dead VFD
As I understand it, conditioning an electrolytic means charge and slow discharge for a number of cycles. Sometimes difficult when the component is in circuit. I tried to find out the recommended parameters, but there has been little or nothing posted on t'Interweb.
Nick, Can you give us some pointers to the procedure for in-circuit ?
Ta,
Rob
06-07-2016 #2
For capacitors made in the past 20 years you do not need to condition them after a period of not using them. For an explanation as to why have a look here https://en.wikipedia.org/wiki/Alumin...rage_or_disuse
In most cases it is impractical to do this process on equipment without a major dismantle, which may cause additional damage.
Graeme
The Following User Says Thank You to Graeme For This Useful Post:
06-07-2016 #3
so i used the machine today for about a hour and its worked perfect, the spindle was fine and did not do anything out of the ordinary! so the mystery is still out there!
06-07-2016 #4
09-07-2016 #5
07-07-2016 #6
The Siemens Micromaster 440 is considerably less than 20 years old and yet -
page 23 - https://inverterdrive.com/file/sieme...ter-440-manual
I would always recommend reading Manufacturer's Manuals rather than relying on a quick Google where mains voltages and complex systems are concerned ;-)
- Nick
It's been brought to my attention, again, that this is not the case for most electrolytic capacitors so thinking Siemens might be a one-off I checked the manufacturer of my nearest tot the door non-Siemens drive (ABB on my 3hp mill/drill) and found this -
https://library.e.abb.com/public/cf2...ming_Rev_G.pdf
Mitsubishi and Omron seem to suggest inspection & testing prior to installation.
In short RTFM as Wikipedia and Google might be right or it might just get you some magic smoke ;-)
Enjoy!Last edited by magicniner; 08-07-2016 at 09:35 PM.
WANTED: TB6560 + PSU, Drivers, BOB's, Nema 23 Kits DEAD or ALIVE
By longy in forum Items WantedReplies: 4Last Post: 16-06-2014, 04:15 PM -
HELP Please 24V power supply went dead
By m.marino in forum General ElectronicsReplies: 7Last Post: 22-10-2009, 12:41 PM -
Dead pillar drill...
By irving2008 in forum Machine DiscussionReplies: 11Last Post: 27-10-2008, 03:54 PM -
Motherboard Dead?
By m_c in forum MotherboardsReplies: 4Last Post: 08-09-2008, 04:25 PM
