Hank you are on to something here as i bought a tile cutter for £20 from Wickes, modified the top plate and mounted a piece of worktop as a face plate. i use it as a bench sander with 8" self adhesive backed sanding discs stuck to the Formica side. I did think about buying another just for the same purpose as you are thinking. The motor in these are just a converted grinder in the one i had.
20-07-2009 #2
I can't seem to establish whether it's possible to adjust the height of the saw blade! That one I linked to on Tescos, clearly has a bevel/angle adjustment knob, but I can't see anything else (doesn't mean to say it hasn't got one).
Does your Wickes tile cutter come with a blade depth adjuster? (presumably it's very noisy too?)
Edit: BTW John...I can't find one of these for a tenner anywhere on Ebay?
20-07-2009 #3
machine mart have a £50 150mm cutoff saw similar to the Silverline one but the problem with these small ones is the limited work size... 25 x 15mm
£80 gets you 50mm and £103 gets you 52mm work size... still not good enough for 60mm ali section
but £80 gets you 65mm as long as you can find a suitable blade for ali...Last edited by irving2008; 20-07-2009 at 06:09 PM.
20-07-2009 #4
Unfortunately it does not have height adjustment as i suppose they don't expect you to cut anything thick than about 12 - 15mm which would max thickness of a floor tile.
20-07-2009 #5
20-07-2009 #6
You weren't gonna buy one unless you had secured all of the knowledge...lol:heehee:
WANTED: Hobby CNC Mill
By smartbusa in forum Items WantedReplies: 3Last Post: 08-10-2013, 09:42 AM -
Tile / Repeat G-Code?
By Tenson in forum Programmers CornerReplies: 27Last Post: 23-09-2013, 08:17 PM -
NEW MEMBER: Just joined, hobby level
By cncgcg in forum New Member IntroductionsReplies: 12Last Post: 03-12-2011, 02:32 PM -
RFQ: Parts for my hobby from your hobby
By Phobia1 in forum Projects, Jobs & RequestsReplies: 1Last Post: 18-01-2011, 02:57 PM -
NEW MEMBER: It's now officially a hobby!
By Ionman in forum New Member IntroductionsReplies: 1Last Post: 30-12-2010, 08:58 PM
