    id love to replace the spindle on my machine with a faster one. my machine currently has an atc so its needs to be an atc spindle.
    anyone recommend any atc spindles? only needs to be like 2-3kw, nothing silly.
    as with everything in life it comes down to cost, but id like some suggestions so I can find out some costs
    Is this for a router? What taper type you running?
    https://emvioeng.com
    Mill that's why I posted in the mill section not router ��
    I'll buy new tooling if I have to
    Sorry Andy, didn't see the whole breadcrumb line on my screen.
    Remind us, what machine is this for? The Denford?
    it is for my denford triac.
    I have two options as I see it.
    current setup on the triac is servo motor drives atc spindle via a belt. now looking at the specs of belts I could put one of those Chinese 24k spindles in and replace just the servo motor, but the belt would be right on its limits of speed.
    or other option would be to get an expensive atc spindle all in one and replace the whole lot.
    current tooling is bt35, but im never going to find a bt35 spindle so new tooling will be required.
    The typically 24,000 rpm chinese spindles are not suitable for use on a mill, and won't last long.
    AliExpress has a lot of BT30 ATC spindles.
    http://www.aliexpress.com/item/ATC-s...d-99c3fa989e32
    Gerry
    UCCNC 2022 Screenset
    Mach3 2010 Screenset
  7. The Following User Says Thank You to Ger21 For This Useful Post:
  8. #7
    Lives in East Lothian, United Kingdom. Last Activity: 18 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 2,992. Received thanks 376 times, giving thanks to others 9 times.
    One thing I find odd about all those ATC cartridges, is I've never seen any threads where people have actually used one. I've certainly never seen anybody complaining about them anywhere, so I'd assume they must do their job without any issues.
    Another option to consider, is there a few Taiwanese spindle manufacturers who do built-in (aka with motor built in) spindles, however I've got no idea on pricing.
    POSA, and Royal Spindles are two that I can remember, but I'm sure there are others.
  9. #8
    due to my setup I would hope a Chinese spindle would last long.
    it wouldn't be directly cutting, it would be connected via a belt to the atc spindle which does the cutting. the Chinese motor would be driving the spindle
  10. #9
    Quote Originally Posted by andy_con View Post
    What belt exactly are you planning to use for that?
    The one that's already in there doing the same job
  1. Recommend me a Laser cutter.
    By Gasgasbones in forum Laser Machines & Building
    Last Post: 07-06-2015, 04:45 PM
  2. EXPERIENCE: Would recommend - CNC Company in Notts.
    By TonyD in forum Trading Experience & Feedback
    Last Post: 15-04-2013, 08:06 PM
  3. Which kit would you recommend?
    By ian823478 in forum Motor Drivers & Controllers
    Last Post: 08-04-2012, 11:05 PM
  4. Can anyone recommend a spindle for milling PCB and cast acrylic?
    Last Post: 11-10-2011, 08:54 PM
  5. Please Recommend me a CNC mill for....
    By Gasgasbones in forum General Discussion
    Last Post: 29-11-2010, 07:17 PM
