03-08-2016 #1Gerry
UCCNC 2022 Screenset
Mach3 2010 Screenset
The Following User Says Thank You to Ger21 For This Useful Post:
03-08-2016 #2
Excellent, i like known issues :)
At least there is a reason.
I ran a couple of parts earlier this week using Mach3 at 300% without noticeable jerkiness on the curves.
Different versions have different issues, mine doesn't seem to have jerky curves above 100% feedrate, I'll check the version but it's the one most recommended for general use on the Mach3 forum,
03-08-2016 #4
I think that the issue is PC dependent, and doesn't affect everyone. But it is an issue, and was confirmed by Art, the author of Mach3.
The Machsupport forum is down right now, but I'll try to find some more info when it's back up.Last edited by Ger21; 03-08-2016 at 02:29 PM.
Gerry
03-08-2016 #5
Does using a external motion controller make any difference - is the jerking only when using parallel port?
03-08-2016 #6
Why do you use FRO at 300%?
Program the feed closer and just go up to 70 or 80%.
Most professional controllers won't allow more than 100%John S -
03-08-2016 #7
This is with a motion controller, UC100
As i said, i was only doing a dry run so speed was irrelevant, in reality I have never used FRO or SSO !
04-08-2016 #8
I would normally adjust feed rate to the middle of the green in CAM but it was a one-off job profiling a couple of small ally plates with a new single flute cutter, I realised it could run faster once I started the job so I just wound it up until it felt right rather than going back to CAM.
Aspire v4.5
By m.marino in forum VectricReplies: 6Last Post: 16-05-2015, 04:44 PM -
CNC router occasionally makes jarring noise and home jumps when it does this. Help!!
By itsmillertime in forum Machine DiscussionReplies: 47Last Post: 13-02-2014, 11:49 PM -
control signals to draw a circle
By lakmalp in forum Machine Control SoftwareReplies: 3Last Post: 16-06-2013, 05:52 PM -
Cutting out a circle
By Martin Paul in forum Machine DiscussionReplies: 2Last Post: 19-04-2011, 12:58 AM -
Aspire !!!
By james mcgrew in forum CAD & CAM SoftwareReplies: 2Last Post: 17-01-2009, 02:16 AM
