Page 3 of 3 FirstFirst 123
  1. #21
    so had the feedrate turned up to max, it was very jerky on curves, thats what made me think.
    This is a known issue with Mach3 and Feedrate Override. It works fine when below 100%. but it can cause jerky movement when turned up a lot above 100%.
    I don't recall if there's a safe max to use, but I would keep it below 125%.
    Gerry
    UCCNC 2022 Screenset
    Mach3 2010 Screenset
  2. The Following User Says Thank You to Ger21 For This Useful Post:
  3. #22
    Excellent, i like known issues :)
    At least there is a reason.
    I ran a couple of parts earlier this week using Mach3 at 300% without noticeable jerkiness on the curves.
    Different versions have different issues, mine doesn't seem to have jerky curves above 100% feedrate, I'll check the version but it's the one most recommended for general use on the Mach3 forum,
    - Nick
  5. #24
    I think that the issue is PC dependent, and doesn't affect everyone. But it is an issue, and was confirmed by Art, the author of Mach3.
    The Machsupport forum is down right now, but I'll try to find some more info when it's back up.
    Gerry
  6. The Following User Says Thank You to Ger21 For This Useful Post:
  7. #25
    Lives in Plymouth, United Kingdom. Last Activity: 2 Weeks Ago Has a total post count of 1,749. Received thanks 299 times, giving thanks to others 11 times.
    Does using a external motion controller make any difference - is the jerking only when using parallel port?
  8. #26
    Why do you use FRO at 300%?
    Program the feed closer and just go up to 70 or 80%.
    Most professional controllers won't allow more than 100%
    John S -
  9. #27
    This is with a motion controller, UC100
    As i said, i was only doing a dry run so speed was irrelevant, in reality I have never used FRO or SSO !
  10. #28
    I would normally adjust feed rate to the middle of the green in CAM but it was a one-off job profiling a couple of small ally plates with a new single flute cutter, I realised it could run faster once I started the job so I just wound it up until it felt right rather than going back to CAM.
    - Nick
  11. #29
    Is the Mach forum having issues - i have not been able to load it since early yesterday morning???
  12. #30
    Yes, I mentioned it in my previous post.
    Gerry
There are currently 21 users browsing this thread. (0 members and 21 guests)
  1. Aspire v4.5
    By m.marino in forum Vectric
    Last Post: 16-05-2015, 04:44 PM
  2. Replies: 47
    Last Post: 13-02-2014, 11:49 PM
  3. control signals to draw a circle
    By lakmalp in forum Machine Control Software
    Last Post: 16-06-2013, 05:52 PM
  4. Cutting out a circle
    By Martin Paul in forum Machine Discussion
    Last Post: 19-04-2011, 12:58 AM
  5. Aspire !!!
    By james mcgrew in forum CAD & CAM Software
    Last Post: 17-01-2009, 02:16 AM
