Hello All, I want to start developing my own CNC machine and I found different designs in the internet.
I want to know how to choose the best design and why should every design be better in some field.
I want to read more about this and need your help
Post the designs your considering as options?
What is your chosen field?
.MeLee
17-07-2016 #3
18-07-2016 #4
The Following User Says Thank You to Lee Roberts For This Useful Post:
18-07-2016 #5
Each machine is designed to cut different types and sizes of materials. For example:
1) Engraving small objects -
Type: Fixed gantry, moving bed
Movement: Ballscrew, Leadscrew, or direct belt
Feedrate: Low
Stiffness: Low
Rails: Supported round
Accuracy: Low
2) Large wood or plastic sheets -
Type: Moving gantry with side legs
Movement: Ballscrew, or more likely rack & pinion (size and feed makes ballscrews less desired)
Feedrate: High (to cut properly and prevent burning)
Stiffness: Medium
Rails: Supported round, or profile rail
Accuracy: Medium
3) Large aluminium parts-
Type: Moving gantry with raised X-axis (no side legs on gantry)
Movement: Ballscrews
Feedrate: Medium
Stiffness: High
Rails: Profile rail
Accuracy: Fairly high
4) Small aluminium/steel parts -
Feedrate: Medium
Stiffness: Very high
Rails: Profile Rail
Accuracy: High
(or convert a milling machine to CNC)
You can argue the details for the above but the point is that depending on what you want to cut, how big it is, etc. it will have conflicting requirements. That is why there are so many different machines out there. If you use a machine to cut a different part to which it was designed it will either be slow, dull the cutter, or not give the accuracy you need.
As Lee says, tell us the sizes and materials you want to cut and that will help narrow down the best options.Last edited by routercnc; 18-07-2016 at 05:57 PM.
The Following 2 Users Say Thank You to routercnc For This Useful Post:
18-07-2016 #6
Y-Axis Designs
By Cyclonit in forum Gantry/Router Machines & BuildingReplies: 2Last Post: 24-06-2014, 02:20 PM -
Mechanical Advice
By Pheet in forum Gantry/Router Machines & BuildingReplies: 5Last Post: 06-10-2013, 02:39 PM -
CNC Mechanical Service / Installation Enginner
By Simon@Alecto_Recruitment in forum Opportunities Available & SoughtReplies: 0Last Post: 03-07-2013, 04:35 PM -
SBR v TBR - Comparison
By Karl in forum Rails, Guideways & BearingsReplies: 0Last Post: 30-05-2012, 12:02 PM -
Breakout Board Comparison
By 200thhorseman in forum Gantry/Router Machines & BuildingReplies: 4Last Post: 27-03-2012, 12:28 AM
