Most of those little 400w "spindles" come with controllers that use a pot to control the speed. You should be able to use the PWM signal from Mach3 and convert it to a 0-5V signal to use in place of the pot.
But really, you're better off buying a real spindle.Gerry
UCCNC 2022 Screenset
Mach3 2010 Screenset
The Following User Says Thank You to Ger21 For This Useful Post:
24-07-2016 #2
25-07-2016 #3
Yes Clive that is the machine it is for, it's been a long build but it will get finished one day lol! Family life takes over and it keeps having to be put on hold.
I'll leave the 400w spindle then, I was expecting that answer tbh!
I'll save up and get the water cooled spindle then, I will have to get some new brackets made to mount it tho so may take me a bit longer. I used to be a machinist in a heavy engineering workshop so had access to making pretty much anything I wanted back then, but now I'm in an office job I'm limited to asking my old work mates to make bits for me!
Do you have a link to one of those spindles Boyan?
Thanks for the advice everyone!
25-07-2016 #4
0.8kw spindle, its ok to buy it together with the chinese VFD drive, which many people use. I use one for my 3kw spindle , price wise. But for smaller motors i personally use and prefer the Toshiba VFD
With the correct cutter 0.8kw spindle does not have problem to go up to 1/4 deep in aluminum with 1/4 carbide bit, provided mist coolingLast edited by Boyan Silyavski; 25-07-2016 at 01:48 PM.
25-07-2016 #5
The 0.8Kw spindle are only 65mm Dia. Think first if you are going to build a bigger machine in the future as the 1.5Kw or 2.2Kw are not much more money and they have a bigger collet
26-07-2016 #6
I did make a mistake when building my machine to not account for a bigger spindle, but who doesn't make mistakes on there first build lol?
The idea of this build was just to get me going and learn from it so that when i wanted to make a bigger and better machine i would have a better understanding of machine building. However since my circumstances have now changed considerably (ie 2 kids and changing jobs) the likely-hood of me building a second machine is pretty slim.
with regards to spindles, are the air cooled ones really much worse than the water cooled? because i'm under the impression that the water cooled system requires a separate water tank and pump? which would just put the price up further.
26-07-2016 #7
What are you looking to cut with your machine? Have you thought of making a brushless DC spindle like in this thread? I've made one and although not used it yet Jonathan and Mark have used theirs with good effect. They are controlled with cheap servo testers and a brushless Radio Controlled ESC.
26-07-2016 #8The air cooled are very noisy not necessary worse. The water cooled only require a very small fish tank pump £3 http://www.ebay.co.uk/itm/Ultra-Quie...uYAAOSwR5dXREE~are the air cooled ones really much worse than the water cooled? because i'm under the impression that the water cooled system requires a separate water tank and pump? which would just put the price up further.
and a 2 ltr Tupperware container for the water...Clive
TB6560 controller Runs spindle on power up When Mach3 plunges spindle stops
By RoyT in forum Spindles & Drive MotorsReplies: 5Last Post: 29-09-2014, 02:42 PM -
budget diy cnc controller question
By dangerousdave in forum Motor Drivers & ControllersReplies: 54Last Post: 29-08-2014, 01:45 PM -
FOR SALE: SuperPID v2 (Closed-loop PID Router Speed Controller)
By Mad Professor in forum Items For SaleReplies: 18Last Post: 23-04-2013, 10:48 AM -
Interact series 2 speed controller problem
By fastcarl in forum Machine DiscussionReplies: 1Last Post: 25-01-2011, 09:50 PM -
Laptop controller question.
By m.marino in forum Laptops & TabletsReplies: 0Last Post: 07-01-2009, 04:33 PM
