02-08-2016 #12
Exactly. ...and one choice is not necessarily worse or better than the other. It seems that not everyone understands the meaning of this simple word called "choice".
I don't know if that clogging spindle is really such a problem in reality. Yes, dust is an issue, especially with wood, but even with water cooled, one should still have dust extraction. I can't for my life understand people milling wood on CNCs day in and day out and not installing any dust shoe, regardless if they use water cooled or air cooled spindles. If nothing else, they should think about their own health.
Like I said to the OP... compared to air cooled 400W DC motor, or any other air cooled spindles, like the pretty popular Kress, the brush less air cooled motors are pretty quiet and DEFINITELY not noisier that the those compared with at the same speed. I never said water cooled are not quieter that air cooled brush less motors. On the other hand, in my case I have used an air cooled 400W DC motor for one year, and the noise of the motor is definitely not a lot at maximum speed (12k RPM). I compared it with my air cooled brushless spindle and that is DEFINITELY even quieter. Once milling starts the motor noise is totally gone, overtaken by the cutting noise even though I basically only cut plastics. That cutter noise would be EXACTLY the same regardless if I used a water cooled spindle or air cooled one. Comparing the spindle at 24k RPM with the DC motor at 12k RPM is pointless, of course that the spindle is noisier in that case, just like if I drive at 100 kmh and then accelerate to 200kmh, engine noise will increase even in the best car. So the noise argument for my part is just nonsense. But, never the less, of course, I understand that by eliminating the fan and closing in the motor, like it is in a water cooled one, that motor generates less no load noise that one with a fan inside and holes right through. Also, as I said, if I'd run my CNC for many hours a day and 5-6 days a week I would not hesitate installing a water cooled spindle, but I don't, so for me life is easier with an air cooled one.
It is wasting water never the less. Very anti-environmental, considering the majority of earth does not even have access to potable water for their survival. Never the less, yes, that's an option if one is keen on saving a few bucks or have his CNC near enough to water. Again, I just described MY needs and MY choice. I know there are many other alternatives and many options to how water cooling can be done, but using air cooled spindle is one such option if there is no need for water cooled one.
Yes, I am aware of those prices and 35$ is more reasonable than the previously mentioned £3. I would not even touch a pump that cheap. Never the less, I don't know why people bring up costs as an issue. Why does everyone assume that cost savings was something I consider against water cooled spindles? On the other hand, if I'd go for a water cooled spindle I'd buy quality parts because it is indeed a critical part of the spindle. After all, if the pump fails your spindle will send smoke signals after a few minutes...
Actually, pumps can fail, they have indeed elements that can fail, but they don't rotate as fast as a fan in the spindle. Anyway, I have so far not heard of fan failure in these spindles. It can happen, I know that, but in really... anything can break, even a water cooled spindle or a pump.
I don't doubt at all that there are advantages of water cooled spindles. Where did you get such an idea? All I try to say that it is not needed, nor necessary for everyone and that not everyone wants one. You said it yourself, "Its a question of choice". It is not necessary to have one SINGLE choice for all, that's not choice...Last edited by A_Camera; 02-08-2016 at 09:45 AM.
TB6560 controller Runs spindle on power up When Mach3 plunges spindle stops
By RoyT in forum Spindles & Drive MotorsReplies: 5Last Post: 29-09-2014, 02:42 PM -
budget diy cnc controller question
By dangerousdave in forum Motor Drivers & ControllersReplies: 54Last Post: 29-08-2014, 01:45 PM -
FOR SALE: SuperPID v2 (Closed-loop PID Router Speed Controller)
By Mad Professor in forum Items For SaleReplies: 18Last Post: 23-04-2013, 10:48 AM -
Interact series 2 speed controller problem
By fastcarl in forum Machine DiscussionReplies: 1Last Post: 25-01-2011, 09:50 PM -
Laptop controller question.
By m.marino in forum Laptops & TabletsReplies: 0Last Post: 07-01-2009, 04:33 PM
