    Quote Originally Posted by ammaratef45 View Post
    Dear All,
    I'm going to make CNC machine prototype - I need it to be closed frame because that will be easier in the control design because I'm going to use servo motors instead of stepper motors
    So I need closed frame design that i can build and apply the control I will design on it
    Any help is welcome, I mainly need small mechanical closed frame design
    Thanks everybody
    What do you mean by closed frame ? Is it like a commercial machining centre with an enclosure
    Also steppers are very capable - do you need servos?
  2. The Following User Says Thank You to routercnc For This Useful Post:
  3. #2
    I need servo cause i want to test control theories - it is graduation project
    I need design ready and tried cause my major is not mechanical engineering and i need this task (mechanical body) to be easy
    And finally closed frame word is not my own description
    I got it from book >> this is the chapter described that part https://drive.google.com/open?id=0B1El2XHLhbSCU1hYX1hTbUZfeVE
    Any clarification will be helpful
    I really thank you for your reply
    OK. So a 'closed frame' is a 'fixed gantry' and an 'open frame' is like a conventional milling machine.
    Good example of a 'closed frame' here, first picture in post#1
    http://www.mycncuk.com/threads/9616-...d-that-be-Zeus
    But there are not many fixed gantry machines on this forum, most are another type with a moving gantry to cut bigger pieces. But have a look through the build logs:
    http://www.mycncuk.com/forums/253-DIY-Router-Build-Logs
  5. The Following User Says Thank You to routercnc For This Useful Post:
  6. #4
    Sorry I'm confused here, But i think the gantry is moving in the picture provided in the link! isn't it?
  7. #5
    The gantry is the large fixed frame connected to the bed, in the shape of an arch. It does not move.
    The X axis carriage moves the Z spindle plate left to right on this fixed gantry.
    The Z axis spindle plate moves the spindle up and down
    On the bed the Y axis plate moves the workpiece left to right.
    Hope that helps.
    Here is diesel's [closed frame / fixed gantry] machine:
    http://www.mycncuk.com/threads/8510-...t=fixed+gantry
    Here is Wals' [open frame / mill style] machine:
    http://www.mycncuk.com/threads/7001-...t=fixed+gantry
    (If you are going for max performance then use profile linear rails (Hiwin etc.) not supported rail.
  8. The Following User Says Thank You to routercnc For This Useful Post:
  9. #6
    The way i see it your best bet is to make a simple fixed gantry machine from aluminium extrusions like the one at the picture bellow
    And maybe make it more miniature and enclose it like that:
Name:	Nomad CNC mill-1.jpg
    So at the end you finish with a benchtop CNC.
    My advice is thought to use at least round supported rails /SBR, TBR..20 size/ , even better, Hiwin 20 / much more expensive and better/ and 0.8kw water cooled spindle. Use also 3nm nema 23 motors and Am 822 drives, PSU for motors non regulated at 70VDC
    I mean when you will be spending money make a real machine that will later have some value. Otherwise go ultra cheap all in one board with drives, 24v motors, PC ATC power supply , nema 17 motors. A micro CNC, similar to 3d printers. The middle way between what i am suggesting, is to spend your money for nothing.
  10. The Following User Says Thank You to Boyan Silyavski For This Useful Post:
  11. #7
    Thank you very much .. can I find CAD file for design like you posted?
  12. #8
    Hope that helps.
    That is awesome clarification .. Thanks very much
  1. BUILD LOG: Well here goes... Aluminium frame router design
    By CharlieRam in forum DIY Router Build Logs
    Last Post: 11-05-2020, 12:39 PM
  2. CNC Frame Design Help
    By zhenning in forum Gantry/Router Machines & Building
    Last Post: 26-12-2015, 05:44 PM
  3. BUILD LOG: Steel frame cnc router design/build
  4. Basic Frame Design
    By Ross77 in forum Machine Frames & Beds
    Last Post: 04-01-2015, 01:33 AM
  5. Alu 40x40 frame - strength/design question
    By Rogue in forum Gantry/Router Machines & Building
    Last Post: 12-11-2011, 05:02 PM
