Thread: Emco PC120 Turn
So, since I have changed my PSU, my steppers dont seem to want to perform. It could be a cheap PSU however not sure.
If I am going to add in another PSU, should I try and increase the voltage? I cant see the exact number, I cant find these drives anywhere - but lets assume it will take 48V DC. I also need to check if the current settings are correct for the specific voltage. Currently everything runs off a 24V 10A supply.
Would it be 'good practice' to try and get the voltage as high as possible?
10-08-2017 #2
Chaz its hard to see but if you look on the driver it gives the max voltage at bottom RH side (48V?) if so you could run them at say about 36V. Do yourself a favour and buy some decent drives like AM882 and run them at a higher voltage.
Also you don't say what PS you are using switch mode are not good for steppers.Last edited by Clive S; 10-08-2017 at 10:10 AM.
10-08-2017 #3
Ye, possibly around 50V.
They did work well before the previous set of PSUs died. The current PSU is one of them el cheapo ebay ones, I presume they are SMPS.
Id like to sell the lathe but need it to be 100% reliable before I do. Any suggestions on what PSU would suit if I was just going to upgrade this? Lets assume 36 or 48V max.
lll take a look at the AM882 anyways.
My best bet is probably something like this.
http://www.zappautomation.co.uk/elec...-supply-7.html
Move the drive power to this, leave the 24V supply to do the logic stuff only.
10-08-2017 #5
http://www.zappautomation.co.uk/elec...-supplies.html
edit you beat me to it or build oneLast edited by Clive S; 10-08-2017 at 10:31 AM.
10-08-2017 #6
This driver is a three phase driver (For Three phase stepper motors) Looking at the part number it implies that the maximum voltage is 80V DC and the current is 6.0 A.
3 = three phase
M = Motor driver
8 = Max voltage (80V)
60 = 6.0 A maximum current.
This is the typical makeup of the part numbers.
Visit Us: www.automationshop.co.uk
10-08-2017 #7
Thanks Gary. I looked on your and a few other sites to try and find who makes this driver, but no such luck.
I also know little about the motors, it was all fit by someone before I bought the lathe. Not a bad job overall. The PSUs that failed looked to be fairly high end things, but voltage is only 24V.
10-08-2017 #8
Using that search phrase, Ive found this, similar.
http://www.ebay.co.uk/itm/CNC-3-Phas...p2047675.l2557
https://www.dhgate.com/product/new-c...126671364.html
I might be able to find the manufacturer spec eventually
10-08-2017 #9
Bingo, I think.
http://www.jmc-driver.com/h-pd-155.h...M860&_pp=0_334
10-08-2017 #10Visit Us: www.automationshop.co.uk
Mach Turn
By Kai in forum CAD & CAM SoftwareReplies: 5Last Post: 02-08-2016, 02:40 PM -
Denford Star Turn 3
By MarkBrown in forum Workshop & EquipmentReplies: 2Last Post: 02-12-2014, 10:57 PM -
Getting the stepper to turn
By thorphar in forum General ElectronicsReplies: 0Last Post: 16-09-2014, 07:48 PM -
11 hours of trying to get the motors to turn, help please
By Wotsit in forum Stepper & Servo MotorsReplies: 19Last Post: 05-02-2013, 03:07 AM -
LED not turn on
By Awel in forum Motor Drivers & ControllersReplies: 1Last Post: 06-12-2011, 06:59 AM
