Thread: Emco PC120 Turn
  1. This driver is a three phase driver (For Three phase stepper motors) Looking at the part number it implies that the maximum voltage is 80V DC and the current is 6.0 A.
    3 = three phase
    M = Motor driver
    8 = Max voltage (80V)
    60 = 6.0 A maximum current.
    This is the typical makeup of the part numbers.
    Ye, possibly around 50V.
    They did work well before the previous set of PSUs died. The current PSU is one of them el cheapo ebay ones, I presume they are SMPS.
    Id like to sell the lathe but need it to be 100% reliable before I do. Any suggestions on what PSU would suit if I was just going to upgrade this? Lets assume 36 or 48V max.
    lll take a look at the AM882 anyways.
    Chaz's Avatar
    Quote Originally Posted by Gary View Post
    3 = three phase
    M = Motor driver
    Thanks Gary. I looked on your and a few other sites to try and find who makes this driver, but no such luck.
    I also know little about the motors, it was all fit by someone before I bought the lathe. Not a bad job overall. The PSUs that failed looked to be fairly high end things, but voltage is only 24V.
    Chaz's Avatar
    Using that search phrase, Ive found this, similar.
    http://www.ebay.co.uk/itm/CNC-3-Phas...p2047675.l2557
    https://www.dhgate.com/product/new-c...126671364.html
    I might be able to find the manufacturer spec eventually
    Chaz's Avatar
  5. So the 6 is RMA current and its up to 80V DC.
    Chaz's Avatar
    RMS ? ;p
  7. Yes RMS, have big manly fingers and the a and the s are quite close.
    Chaz's Avatar
    Plus, you deal with RMA stuff, so it could have been a finger memory thing. I do it often myself.
    Chaz's Avatar
    Ill also check the current setting - may bump this up (if not max already) and see if its makes the response better.
  1. Mach Turn
    By Kai in forum CAD & CAM Software
    Last Post: 02-08-2016, 02:40 PM
  2. Denford Star Turn 3
    By MarkBrown in forum Workshop & Equipment
    Last Post: 02-12-2014, 10:57 PM
  3. Getting the stepper to turn
    By thorphar in forum General Electronics
    Last Post: 16-09-2014, 07:48 PM
  4. 11 hours of trying to get the motors to turn, help please
    By Wotsit in forum Stepper & Servo Motors
    Last Post: 05-02-2013, 03:07 AM
  5. LED not turn on
    By Awel in forum Motor Drivers & Controllers
    Last Post: 06-12-2011, 06:59 AM
