Thread: Emco PC120 Turn
    Lives in East Lothian, United Kingdom. Last Activity: 4 Days Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 2,994. Received thanks 376 times, giving thanks to others 9 times.
    What diameter would you like to part?
    Chaz's Avatar
    Well, more than 25 if possible. There will be a limit, need to measure the max. With blades this can be adjusted.
    GTN style insert up to 32mm diameter - https://www.shop-apt.co.uk/part-off-...2mm-shank.html
    WDN style insert up to 26mm diameter - https://www.shop-apt.co.uk/external-...max-depth.html
    (APT do do a 32mm version, but they're showing as out of stock)
    I personally use the WDN style, as I couldn't find a reasonably priced 12x12 shank holder for GTN types when I was originally buying holders.
    Chaz's Avatar
    Thanks. This one will be better. What I do need to find out from APT is the size of the 'head'. If its too long, then even cutting some of the rear off doesnt help as the head will protrude. This is the issue I have with the Glanze unit that I have.
    If I remember, I'll get some rough measurements for you when I'm in the workshop later, as I've got a couple different ones.
    Chaz's Avatar
    Thanks. Appreciated. Ive emailed APT support, ive used them in the past and they are really good but finding a parting solution for this otherwise excellent little CNC lathe.
    Realised earlier that I've actually got a GTN style in the lathe just now.
    It's this one - https://www.shop-apt.co.uk/part-off-...2mm-shank.html
    Tip to the back of the head is about 26mm. I only remembered after I'd turned the lathe off, and the parting tool was at a less than ideal angle to accurately measure.
    I also measured a 26mm diameter WDN holder, and the tip to back of head is 21.1mm
  1. Mach Turn
    By Kai in forum CAD & CAM Software
    Last Post: 02-08-2016, 02:40 PM
  2. Denford Star Turn 3
    By MarkBrown in forum Workshop & Equipment
    Last Post: 02-12-2014, 10:57 PM
  3. Getting the stepper to turn
    By thorphar in forum General Electronics
    Last Post: 16-09-2014, 07:48 PM
  4. 11 hours of trying to get the motors to turn, help please
    By Wotsit in forum Stepper & Servo Motors
    Last Post: 05-02-2013, 03:07 AM
  5. LED not turn on
    By Awel in forum Motor Drivers & Controllers
    Last Post: 06-12-2011, 06:59 AM
