Thread: Emco PC120 Turn
They are all over eBay, just search for 'relay module 5v' and limit to UK if you want it fast.
Here's one example of a supplier - http://www.ebay.co.uk/itm/1-2-4-8-16...f5lyx157fF9xGQ
Cheers,
Rob
21-11-2016 #2
Awesome thanks
21-11-2016 #3
That should work well. Does it take much messing about with Mach3 to get this to work?
21-11-2016 #4
I use P16 for coolant (just an air blower really) and P17 to turn the spindle on (Kress, not a three phase one with speed control)
You may like to play with active high / low and whether you connect to NO or NC on the relay as there can be some activity on the pins before Mach3 takes control.
Cheers,
Rob
22-11-2016 #5
23-11-2016 #6
So I ordered this one - https://www.shop-apt.co.uk/part-off-...2mm-shank.html. Its like 2mm too long but I can grind away some of the lip that's in the way. Kudos to APT for the quick delivery as usual.
02-12-2016 #7
Hi, does your lathe have a Baruffaldi TOE80 turret like on a denford cyclone?
http://www.1stmachinery.com/Resource.../1008_6790.JPG
Is so I have a few spare blocks and boring bar sleeves that i made up and also some spare ER25 and ER16 Holders that I bought and modified to suit the 25mm tool holder if you are interested
11-03-2017 #8
So I bought one of these and finally tried to install it today. Nothing works. Ive tried every option. The state of P17 doesnt change, even if I press E Stop whatever. It could be that the board is damaged.
Are you able to indicate what the wiring should look like from a board like this please?
http://www.ebay.co.uk/itm/5-Axis-Cnc...item3d32792356
11-03-2017 #9
Sorry Chaz, but I can't get my CNC fired up at the moment. First, you need the relay jumper disconnected and then in Mach3 you need to command the P17 with an output set to pin17 and that output linked to M8 on the Spindle Control screen, so then M8 in your code sets coolant on and M9 turns it off.
You can use any spare axis pulse or direction pin to do the same thing btw, if you want to use the onboard relay for spindle control, which is hard wired into P17 when the jumper is on.
PM me your Mach3 configuration file (you will need to copy it and change the extension to .txt) and |I will have a look at it. I can't remember exactly where we got on this.
Cheers,
Rob
In the meantime I will look at my CNC PC to see why it is not firing up properly !!!! - Have looked at it system SSD is dead, will need to rebuild Operating system and reload software --- S H I T -- !!!!Last edited by cropwell; 11-03-2017 at 04:32 PM.
11-03-2017 #10
Thanks. Ill get the config later (its in the garage).
I tried with the relay setting on and off. I did damage the board however previously when I miswired the on board relay. Cheap enough to replace. I then made Output 3 try both pin 16 and 17 but nothing changes the state of them. Im using output 3 for coolant and triggering it doesnt change anything. Perhaps I need another board first. Id love to go CS Labs as its something I understand but too pricy for a machine ill likely be selling.
Mach Turn
By Kai in forum CAD & CAM SoftwareReplies: 5Last Post: 02-08-2016, 02:40 PM -
Denford Star Turn 3
By MarkBrown in forum Workshop & EquipmentReplies: 2Last Post: 02-12-2014, 10:57 PM -
Getting the stepper to turn
By thorphar in forum General ElectronicsReplies: 0Last Post: 16-09-2014, 07:48 PM -
11 hours of trying to get the motors to turn, help please
By Wotsit in forum Stepper & Servo MotorsReplies: 19Last Post: 05-02-2013, 03:07 AM -
LED not turn on
By Awel in forum Motor Drivers & ControllersReplies: 1Last Post: 06-12-2011, 06:59 AM
