Thread: Emco PC120 Turn
Page 4 of 15 FirstFirst ... 2345614 ... LastLast
  1. #31
    Lives in East Lothian, United Kingdom. Last Activity: 4 Days Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 2,994. Received thanks 376 times, giving thanks to others 9 times.
    On a lathe X should always move to positive as the tool moves away from centre.
    Even on a lathe with twin turrets, the controller should be smart enough to know what direction is positive depending on what tool/turret is selected, although I think there is a bug in Mach3 when running front and rear turrets.
    G0 is just a rapid move.
    G53 defines machine coordinates, but it's non-modal I.e. you have to put G53 in front of every coordinate to move to machine coordinates, other wise it will default to the active tool/offset coordinates. You would typically use a G53 for the tool change location move.
  2. #32
    And pick either diameter or radius mode. Don't keep switching between them, as that's when you're far more likely to make a mistake.
  3. #33
    Chaz's Avatar
    Thanks. It's working now. I reversed X.
  4. #34
    Chaz's Avatar
    Can anyone help with some G Code in the toolchange Macro please?
    Mine doesnt move the turret out the way but needs to. Ideally Id like to move it to the Machine 0 position.
    I found the original tool change macro that was used on my machine which contains these movement commands however the movement is not consistent (ie different directions depending on where it is, I'm not sure why).
    Code "G01 x-10 F1300"
    Code "G0 z-10"
    I tried to do G53, cant do this in MachTurn.
    I then tried G28 which works however it also tries to 'home' my turret rotation axis, which is not correct.
    How do I simply tell the machine 'go home on the X and Z axis (only and ignore A Axis)'?
    I've used G53 in turn, but never in a macro.
    I always do the tool change position move in G-code, as it gives you more flexibility, and allows you to cut down on wasted travel.
  6. #36
    Chaz's Avatar
    Thanks. So you edit your G Code to 'manually' move the turret? Problem is, G53 doesnt work in Turn for me. Tells me its not supported.
    How else could I tell the machine to go to (machine) home on X and Y only?
  7. #37
    Yes.
    A typical mach tool change for me would of been-
    Code:
    G0 G53 X0 Z0
    T0101
    I say would of been, because I no longer use Mach, but I wrote enough code to know how to get it do what I wanted it to.
    G53 should be valid, as it's telling Mach to use Machine Coordinates (i.e. ignore any tool/work offsets). The only thing I can think of, is do you have a good homing routine, with the axis referenced LEDs turning green after homing/referencing?
    Something tells me if the machine isn't referenced, then machine coordinates might not work.
  8. #38
    Chaz's Avatar
    Yes.
    Code:
    G0 G53 X0 Z0
    T0101
    I reference before I move and I ensure that Machine co Ords are green and Zero. I use this as my 'reference' and my tool offsets are based against the X Home position.
    Ill take a pic tonight but Mach 3 tells me I cant G53 in Mach Turn. It might not like it in the Macro, Ill do an MDI tonight and see.
  9. #39
    Chaz's Avatar
    So inserting G53 X0Z0 works well but I need to copy that into the G Code.
    I am using the default Fanuc post processor in Fusion 360, it would be good to be able to edit the post processing somehow. It also adds G28 commands that my Lathe doesnt like.
  10. #40
    i2i's Avatar
    I've used G53 in Turn, but i think you must specify the axis you need to move. eg. G53 G0 X0.00, and a separate line for the z axis
  1. Mach Turn
    By Kai in forum CAD & CAM Software
    Last Post: 02-08-2016, 02:40 PM
  2. Denford Star Turn 3
    By MarkBrown in forum Workshop & Equipment
    Last Post: 02-12-2014, 10:57 PM
  3. Getting the stepper to turn
    By thorphar in forum General Electronics
    Last Post: 16-09-2014, 07:48 PM
  4. 11 hours of trying to get the motors to turn, help please
    By Wotsit in forum Stepper & Servo Motors
    Last Post: 05-02-2013, 03:07 AM
  5. LED not turn on
    By Awel in forum Motor Drivers & Controllers
    Last Post: 06-12-2011, 06:59 AM
