Thread: Emco PC120 Turn
11-03-2017 #2
5 V +on Vcc on the relay board or you will burn it out !
11-03-2017 #3
Chaz wrong time of night for sense
But I think you need to supply the bob with two power supplies one 5V and the other 12-24V before you will get any sense from it. Those bob's are £3,20 from ebay (China) inc PoP
12-03-2017 #4
12-03-2017 #5
If you have set up the BoB OK with 12-24v GND and 5v from the PC using the USB cable AND the jumper on the BoB is off, AND ports and pins are set properly in Mach3, - then if your BoB is working it should work.
At the moment I am very pissed off that I have to rebuild my system from square 1 as after the hard drive failure, I have to reload all software. Fortunately I backed up all the work files but the Mach3 .xml has been lost and I thought I had a backup, but can't find it, so it looks like I have to go back to basics. I was up till 4:30 this morning trying to sort it, so I think today will be a 'FCUK It' day.
12-03-2017 #6
12-03-2017 #7
Pretty sure the BOB is screwed. I tried to use its relay output and did something wrong. So a new one should be ordered I believe.
25-03-2017 #8
Fcking electronics.
New BOB, all works. Awesome.
I then start to permanently solder the wires. I solder the 0V Gnd wire, sparks. Seems like my 24V PSU (x 2) have taken offence to me soldering whilst they were powered and both are now faulty. Really surprised. On my machine, they simply dont power. On the bench, it trips a 16A breaker once the PSU powers. Odd.
Ive got two of these units. 24V 5A each it seems.
http://www.ebay.co.uk/itm/VERO-MONOV...-/281969319232
Ill contact the manufacturer to see if they can look at them or repair.
One PSU powers two of these - http://jmcmotion.en.made-in-china.co...ler-3m860.html - suppose could go higher voltage?
The other powers the BOB and a very small stepper driver for the turret.
Argh.
Mach Turn
By Kai in forum CAD & CAM SoftwareReplies: 5Last Post: 02-08-2016, 02:40 PM -
Denford Star Turn 3
By MarkBrown in forum Workshop & EquipmentReplies: 2Last Post: 02-12-2014, 10:57 PM -
Getting the stepper to turn
By thorphar in forum General ElectronicsReplies: 0Last Post: 16-09-2014, 07:48 PM -
11 hours of trying to get the motors to turn, help please
By Wotsit in forum Stepper & Servo MotorsReplies: 19Last Post: 05-02-2013, 03:07 AM -
LED not turn on
By Awel in forum Motor Drivers & ControllersReplies: 1Last Post: 06-12-2011, 06:59 AM
