Thread: Build Log - Herbert
03-08-2016 #4
Why would you not put the VFD in a control cabinet?
Just because it creates heat and electrical noise is not a reason to not put it in a control cabinet.
Stepper drivers, servo drivers and power supplies create heat and electrical noise and as long as you follow standard electrical engineering practice, then all of these problems can be resolved.
Fitting an IP00 Inverted in a damp and dusty environment is not a great idea and can be dangerous.
Every inverter that i have installed went into a control cabinet and any commercial machine will have the inverter in the control cabinet, so why should it be different because its a hobby machine?
Visit Us: www.automationshop.co.uk
The Following User Says Thank You to Gary For This Useful Post:
BUILD LOG: a Steel Box Section Build with SBR20 & Ballscrews Plus a few questions
By grain_r in forum DIY Router Build LogsReplies: 130Last Post: 27-01-2023, 06:47 PM -
By Karl in forum DIY Router Build LogsReplies: 12Last Post: 08-02-2017, 08:03 PM
