  1. #21
    hi
    im also start use pokey with mach 4 ,im also from israel
    call me we can advise
    yaakov
    tel 972 50 4242775
    [email protected]
  2. #22
    I have been using it for more than a year, what do you need to know ? perhaps i can help
  3. #23
    i now plan use it first time with mach 4 with new cnc from china
    i already bought all parts and take them with me to china
    next month ill be there to test on machine
    first question is about stability, i use spindle ,3 axis ,magazine with servo motors ,drill head with 12 tool s on it
    i plan use the pokeys57 with 5 relay cards and use all optional inputs
    most i fried is from noise and stack machine
    second is very strange to me is that there no input for encoders to controller ,that mean even i use servo motors ,the encoder input only to the servo motor driver ,and not any conection to mach4 to see real position
    thks
    yaakov
  4. #24
    Quote Originally Posted by yaakovKatz View Post
    The only low cost controls that can run in true closed loop are LinuxCNC, and Dynomotions KMotionCNC.
    Gerry
    UCCNC 2022 Screenset
    Mach3 2010 Screenset
  5. #25
    hi
    yaakov
    tel 972 50 4242775
    [email protected]
    I have a new (never used) pokey57cnc with 4 driver for sale i tel aviv if you interested to buy!!
    Sent from my ONEPLUS A3000 using Tapatalk
  6. #26
    send me yours phone please
  7. #27
    do you have experience with Dynomotions KMotionCNC?
    do you think its batter then mach4?
    is it so flexible and can manage like mach4?
    thanks alot
    yaakov
  8. #28
    think i have read somewhere that pokeys57cnc can use encoders on servo's.. but not sure
  9. #29
    Lives in East Lothian, United Kingdom. Last Activity: 17 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 2,994. Received thanks 376 times, giving thanks to others 9 times.
    As Ger says LinuxCNC and KFlop are the only two reasonably priced options that can handle encoders.
    However, unless you're running analogue servos, then there's not really any benefit to feeding back encoders.
    The only real benefit of having encoder feedback on a step/dir (or CW/CCW) system, is for tuning, as it allows you to know exactly how the servo is responding to moves. But once the system is tuned, there is no practical difference between the controller stopping things because of following error, or the servo drive disabling things because of a following error.
    KMotionCNC itself is pretty basic, but it'll do everything you need to control a CNC machine, and the new screen editor does let you alter quite a lot of things. The source code is also provided for KMotionCNC, so you can even modify it if needed (if you want to use non-simple kinematics, then you need to be able compile the required configuration files)
    The real benefit of KFlop is that it is highly configurable, and can be programmed to handle pretty much any configuration of machine with up to 8 axis. And the KMotion configuration software has lots of functionality for tuning servos, along with being able to see encoder/axis positions, In/Out statuses, and a C program editor/compiler for creating the required files to configure the KFlop.
  10. #30
    thanks alot for yours answer
    what tuning you mean? and if it necessary is that mean that with mach4 i cant get good tuning?
    i thought that benefit is that when motor power of(e-stop ) even if you move axis by hand ,controller know real position
    other question is ,with mach4 as i c you can also manage the interface...and many other function
    do you think its less then KFlop?
    thks
    yaakov
  1. Step-Four problems
    By BazzerH in forum General Discussion
    Last Post: 18-03-2020, 11:09 PM
  2. Mach3 Problems problems problems.
    By ECCO in forum Artsoft Mach (3 & 4)
    Last Post: 09-07-2016, 10:07 AM
  3. Help needed! Servo, MACH3 or Pokeys57CNC whats going on?
    By Boyan Silyavski in forum PoLabs (PoKeys)
    Last Post: 23-06-2016, 04:22 PM
  4. tree problems!
    By kingcreaky in forum Woodwork Discussion
    Last Post: 02-06-2014, 12:35 PM
  5. NEW MEMBER: MDF Problems
    By MrWiz73 in forum New Member Introductions
    Last Post: 31-12-2011, 12:39 AM
