Thread: Tutorial Mach 3
07-09-2016 #10
I don't have Mach 3 in front of me right now, but it sounds like you have some sort of configuration issue, and that should be pretty simple to figure out and fix it. It can also be missing/extra steps caused by wiring and electronics, but for now, lets assume that configuration is the most probable cause of your errors. If Z is the only problem and the problem is random, then the most probable cause is the speed and acceleration setting, assuming you don't have binding or other mechanical issues, like broken ball nut, alignment issues or something similar.
Anyway, Mach 3 is not that complicated to understand once you have configured it right. What you need to learn is how to generate G-code, manually or using a CAD software. You don't need to start know everything to start off, but don't expect perfect results immediately. In my opinion it is best to start with air milling until you understand what is happening and why and can identify if an error is caused by the machine, the configuration, or the G-code. Start with simple objects, based on straight lines, first. Mill a square, observe how the axes are moving. If everything seems right, you can start with some softer material, like plastics or MDF, and measure milling depth. If everything is accurate you could create some circular pattern and maybe a start inside, to check that even that is working. To create these patterns you can use manual coding, it gives you an understanding you will need later on with more complex codes. When that is also OK you should move on to some CAD software and try to generate G-code from there. How complicated this is, depends on you and the software of your choice.
Anyway, don't give up just because you get it wrong some times. We ALL get it wrong some times, even the world's best experts. Milling is fun, even if some times can feel like a bit of a too steep climb for amateurs like you and I. Once you understand the basics and set up the machine and Mach 3 you will enjoy it as well, so don't give up, but also give yourself time to practice and allow for some mistakes and failures. Those are part of the learning process, so it is valuable for the future.
Good luck.
The Following User Says Thank You to A_Camera For This Useful Post:
Mach 3 Help
By RichardR in forum Artsoft Mach (3 & 4)Replies: 2Last Post: 04-08-2016, 12:21 PM -
Probe Centering with Mach3 Tutorial
By Ricardoco in forum Probing, Digitizing & ScaningReplies: 9Last Post: 02-07-2016, 07:19 PM -
Mach 3 using laptop and usb
By drftnr34 in forum Motor Drivers & ControllersReplies: 6Last Post: 09-07-2015, 04:38 PM -
BobCad-Cam 3D tutorial
By craigrobbo in forum Computer SoftwareReplies: 0Last Post: 21-09-2012, 06:20 PM -
mach 3 help
By 1albobs in forum Artsoft Mach (3 & 4)Replies: 3Last Post: 27-02-2012, 03:34 PM
