Thread: Multi stepping
    My take on microstepping is that the biggest gain is smoothness of motion and reduced vibration. The increase in resolution is not always the main reason for choosing microstepping. We used to use 1/2 step mode on our machines, now we use 1/8th step. The only change we have made to the controls are to increase the step rate by 4. We now have the same usable resolution but with a much smoother system that has improved acceleration and reliability.
    Hope this helps.
    Simon
    My take on microstepping is that it's fine and dandy so long as there is no load on the motor.
    As you go beyond half step it gets springy. Any stiction means it won't start to move until you're far enough ahead to overcome it, then, suddenly, BOING.
    I half step to 10um then add an intermediate 5um microstep but it's only there to smooth things out, it ain't gonna happen :heehee:
  3. Microstepping is not linear (Between full step positions) and should not be relied upon.
    the error you will see is only between the full step positions.
    I demonstrated this to a customer with a stepper motor set to a high microstepping resolution that had a mirror attached to the shaft and I pointed a laser at the mirror and put a pen mark on the wall on the other side of the room, I then moved the motor 100 microsteps, marked the wall and then moved back 100 microsteps, and the laser was a few cm from the original mark.
    Gearing will be better for accuracy, but you have the downside of smoothness, noise, backlash or hysteresis.
    If you need accuracy and repeatability with very small increments then closed loop servo would be the way to go (PID driver)
  1. Stepping Motors & Drivers
    By irving2008 in forum Stepper & Servo Motors
    Last Post: 28-04-2015, 09:37 PM
  2. Multi thread cutting
    By cropwell in forum Metalwork Discussion
    Last Post: 03-10-2013, 10:32 PM
  3. X axis not stepping
    By m.marino in forum Marchant Dice Machines
    Last Post: 21-04-2009, 08:37 AM
  4. Stepping down from 5v to 3-4.5v
    By Smiler in forum General Electronics
    Last Post: 22-03-2009, 01:45 AM
  5. Wow, stepping 13"/second
    By Robin Hewitt in forum Machine Discussion
    Last Post: 24-11-2008, 11:52 PM
