    I have used an Antex TCS50 for years* and if it gives up before me I would replace it with this https://www.rapidonline.com/antex-t4...d-iron-85-0555
    For big joints I use a large tip to transfer heat quickly, but the tips go down to needle point, 2.3mm is the tip supplied, but I find this one useful https://www.rapidonline.com/antex-b1...s-iron-85-0511
    I have a dislike of the rapid heat guns, I used to have a Russian one with a bakelite case - it was downright dangeroos.
    Cheers,
    Rob
    *Held together with cable ties and superglue now
  2. The Following User Says Thank You to cropwell For This Useful Post:
  3. #2
    Thanks guys, i think it will be either the Antex TCS50W with the digital control integrated /wow/ , either both / JBC2100/
    I used one of the earlier model Antex irons (with analogue temperature control in the handle) for quite a while and with a range of different size bits, it worked quite well. However, it does suffer from "stiff cable" problems - it's a lightweight iron and it's difficult to put it on the bench without it moving - you need a heavy stand to hold it when it is not in use. I now use a (probably more than 30 year old) Weller temperature-controlled iron which came from a scrap bin at work. I had to design and build a new temperature controller for it (Arduino-based) but it works very well, feels good in the hand, and has a very flexible silicone cable that is also heatproof. I don't know if there are any second-hand irons like this still around, but mine is the best iron I have used. You can still buy new bits for it as well. I don't know what the cheap soldering stations from Maplin are like - haven't used one.
  5. #4
    With all this talk, I got hankering for a new brandin' iron. When I read the Antex TCS50 has a silicone burn proof lead, I just had to get me one ! YeeHar !!!
    Rob
  6. #5
    Lives in East Lothian, United Kingdom. Last Activity: 10 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 2,994. Received thanks 376 times, giving thanks to others 9 times.
    I've got to admit, my Hakko FX-888 is probably one of the best investments I've made.
  7. #6
    All soldering irons should come with this as standard!
  8. #7
    Rob
    You are a lucky one. When i started adding things to basket i saw a nice heavy stand for it, then i remembered i need servo cables, then shielded cables for sensors. Then i see now they have pneumatic tools. Maybe i will leave that for tomorrow, with a fresher mind ...
    I've got one of these and love it.
    I can also vouch they are strong.?? . . . Because if you drag it off the bench and run over it with pallet truck they still work. . .Lol
    http://www.circuitspecialists.eu/csi...l&utm_content=
  10. #9
    Thanks Jazz, I have bookmarked the site - look to be good prices there !
  11. #10
    At the end reason won so i bought this all for 21euro from Aliexpress : EU plug CXG 936d Digital LCD Adjustable temperature Electric Soldering station Electric soldering iron 220V 60W solder+ tip10pcs.
    i watched some reviews and all said they work fine. it could have been black not some dodgy colors, but 9$ more, so i decided to be reasonable :-)
    I have ordered and received from TME together with some other cable - 10m silicone 3 wire cable, which is quite nice, so once it comes i will fit some longer nice cable to it. Fit no- solder...
    Plus the tips are for 900 series , means 5$- 10 tips or sth like that.
  12. The Following User Says Thank You to Boyan Silyavski For This Useful Post:
  1. CNC pneumatic bench clamp
    By joss01 in forum General Discussion
    Last Post: 17-11-2018, 05:47 PM
  2. Bench-top or welded frame
    By Doddy in forum Gantry/Router Machines & Building
    Last Post: 05-03-2018, 07:45 PM
  3. Welding bench
    By Boyan Silyavski in forum Metalwork Project Showcase
    Last Post: 12-07-2015, 05:01 PM
  4. WANTED: Boxford 160 tcl bench top cnc lathe
    By sbdtasos in forum Items Wanted
    Last Post: 09-07-2015, 07:48 AM
  5. Bench Top Mill
    By Wobblybootie in forum Milling Machines, Builds & Conversions
    Last Post: 04-06-2010, 06:57 AM
