    hi...i need some help on wiring this tb 6600 v1.2 single axis driver to my bob hy-jk02-m
    Enviado do meu SM-G928F através de Tapatalk
    nobody??
    Look carefully at the row of terminals on the BOB marked XN/XD/XS/XE. XN is ground is left unconnected. XD is "Direction" and goes to the driver Direction terminal. XS is "Step", also known as "Pulse", and goes to the Pulse terminal. XE is "Enable" - I think you can work out where that goes... You then connect the driver +5V terminal to the BOB +5V supply.
    You then have the same thing for Y and Z, plus a fourth axis if needed labelled AN/AD...
    ground from the 5axis bob goes were on the driver? the left side of the driver is for stepper wiring and for the power supply...right?my confussion is the 5v pin on the right side of the driver goes where...
    My mistake - looks like you take the +5V terminal on the driver to the BOB +5V supply. You can leave the enable terminal disconnected as the default with no signal is "enabled".
    ok...tomorrow i will make the wiring and see if works properly...is any chance of burn the driver?
    No, I don't believe that you will burn out the driver making these connections. Even with the error in my first post, you would not do any harm, although it would not work. These drivers are more likely to be damaged by what you connect to the other terminals, and the recommendation is to keep well below the maximum voltages that are given in the data sheet. The data sheet gives a maximum of 48V but you are probably safer to use 36V or less. I have run one of these drivers off a 24V supply without problems although I was not driving a large motor.
    yap...i have a 24v 15amp power supply to connect...in my cnc i have in use 3 driver 2m542 but now i increase de size of the x axis and i have to put another stepper in parallel on my axis...so i dont want to buy another driver igual and have these tb 6600 driver laing around...i will use this to drive my z axis and another 3 driver i use one for drive de x axis and 2 in parallel to drive de y axis...
    Lives in Marple Stockport, United Kingdom. Last Activity: 12 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 3,347. Received thanks 620 times, giving thanks to others 89 times. Made a monetary donation to the upkeep of the community. Is a beta tester for Machinists Network features.
    Quote Originally Posted by weed2all View Post
    As Neale has stated re the top voltage to use but also do not connect or disconnect the motors while the drive is powered with the 36V as this will burn the drive up.
  1. Wiring Diagram check
    By eurikain in forum Electronic Project Building
    Last Post: 08-12-2017, 08:40 PM
  2. Which wiring diagram software do you use ?
    By eurikain in forum Computer Software
    Last Post: 11-10-2015, 02:48 PM
  3. VFD Wiring Diagram
    By Tomnewry in forum General Electronics
    Last Post: 14-10-2013, 06:46 PM
  4. Wiring diagram for 4x4 cnc router
    By Danielroyal25 in forum General Electronics
    Last Post: 19-07-2013, 11:14 PM
  5. NEW MEMBER: Hi, Looking for a wiring diagram, Melbourne
    By Sampop in forum New Member Introductions
    Last Post: 28-10-2010, 11:18 AM
