20-08-2016 #1I don't zero out any backlash because I find that on the lathe you (or I) always back off from X at the end of the cut run and then then any backlash is taken up when you start the next cut. If that makes sense. The conversion I did was from this guy http://www.jeffree.co.uk/modelengineering.htmlSo how is the performance with the original lead screws Clive? can you zero out the backlash in the cross slide?..Clive
Need help with a sensorless vector VFD and 2.2kw motor.
By kajuk in forum Spindles & Drive MotorsReplies: 42Last Post: 04-06-2015, 10:54 PM -
By kajuk in forum Spindles & Drive MotorsReplies: 0Last Post: 29-01-2014, 06:09 PM -
bitmap to vector conversion
By GEOFFREY in forum Computer SoftwareReplies: 16Last Post: 29-12-2012, 06:32 PM -
Closed Loop Stepper Compared with Open Loop Stepper
By Leadshine-Erci in forum Stepper & Servo MotorsReplies: 0Last Post: 25-05-2012, 08:11 AM -
Vector graphics AKA CAD for free
By m.marino in forum Computer SoftwareReplies: 1Last Post: 15-01-2009, 02:17 AM
