    been trying to engrave some clear acrylic to make an led sign for a friend, but its not been going as well as id like.
    first tried a 1mm end mill, 22000rpm, 0.5mm DOC and 500mm/m. acrylic just melted and stick to the cutter and produced a poor finish.
    I then tried a 4mm spot drill, 0.25mm DOC, 22000rpm and 300mm/m. started off very well with a perfect finish then after a while the acrylic melted and stick to the spot drill and gave a crap finish.
    I then tried an 8mm spot drill, 0.25mm DOC, 22000rpm 300mm/m. went ok for about 30 seconds then acrylic melted and stick to the spot drill.
    so decided 4mm spot drill was giving best results and played around with a few different feed rates, I can get good results but then every time after a few mins of cutting the acrylic melts and sticks to the end and causes a shit finish.
    anyone got any tips?
    Lives in Marple Stockport, United Kingdom. Last Activity: 18 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 3,348. Received thanks 620 times, giving thanks to others 90 times. Made a monetary donation to the upkeep of the community. Is a beta tester for Machinists Network features.
    The little bit of acrylic that I have done was using a lot higher feed rate than 300mm/min so I would do some tests at say 2-3 mtr/min. There are people on here that do cut that stuff though and hopefully will chime in.
    I have had reasonable results using lots of air to clear chips and WD40 or Fixt spray to keep the cutter lubricated and cool. A sharp carbide single flute cutter with open architecture (lots of space in the spiral, to allow chips to get out of the way) helps. You also need to make chips that take the heat away, not rub the plastic.
  5. #4
    Quote Originally Posted by andy_con View Post
    welcome to the world of plastics
    I don't remember right now what machine you had, but plastics melt if machine is not rigid or if you push cutter so it passes some minimum deflection. Plus they need constant air cooling. Or one flute cutters. But could be done without melting if you don't dig deep.
    V cutter is not same as spot drill, but anyways. At least it must be very sharp. That's a rule for plastics. New and sharp! Try 0.025mm chip load and 0.1-0.2mm pass. It would help if you file a bit that tip flat. say 0.4- 0.6mm at least. Cause you know there starts the burning. Not digging deep means you could pass without any cooling at all.
    +1 to this, also the single flute cutters are easy to sharpen with a little practice.
    I made some covers for Theoben airgun magazines in acrylic and flame polished the inside (machined) surface to achieve good transparency,
    - Nick
  7. #6
    the single flute cutters are easy to sharpen with a little practice. - Nick
    Never had one go blunt, had plenty of the feckers snap though!
  8. #7
    thanks for all the info
    I have a denford micro router, which is enclosed. I did wonder if things in general were getting hot yesterday, it was a hot day and once I closed the door of the router there is no air movement inside.
    how small can you get single flute cutters? I want to engrave so didn't want to go any bigger than 1mm really
  9. #8
    I use V-bits to engrave, but when I am milling acrylic I am using single flute bits. Feed rate depends on the type and diameter of the mill bit and the DOC. My current crappy DC motor I have as spindle is running at 9000 RPM and the feed rate for engraving with V-bits is normally around 300mm/min. Milling with 2, 3 and 4mm end mills I normally run with 500-900mm/min feed rates.
    So my advise for you is to use single flute end mills and V-bits for engraving and reduce the spindle speed by 50% and keep everything as it is. If you still experience melting then reduce the spindle speed even more and find an optimal speed when melting stops. Once you found that you can increase feed rate and spindle speed.
    Remember that the 0.25mm DOC is more like shaving than cutting material, the chips are very thin and can not transport away the heat very efficiently. Use a vacuum cleaner to keep the surface clean to avoid milling the already milled material and making even more tinier chips. If you manage to keep the track of the bit clean then you don't need cooling and the edges will be fine. CA good dust/chip extraction is more important than cooling. Blowing air may work, but I found that at least for me, vacuum is much better. It is also more pleasant to use than blowing plastic chips and dust around the room and all over the machine.
    What I also experienced problems with is that the protective sheet some times is of a material which melts considerably easier than the acrylic it is protecting, and that is a real problem. You can't run the machine and adjust to the protective sheet, because that will cause problems with milling the acrylic. In those cases I remove the protective sheet before I start milling, because once the protective sheet starts melting it will destroy the work piece as well and will continue melting, taking the acrylic with it and may also destroy your bits.
    In my experience, acrylic is a lot of trial and error. What one person is saying is working for him is not always the same that will work for you, unless we would use the same plastic and every other parameter would be the same. There are different material qualities, so just because it is clear acrylic, it is not that all clear acrylics are the same. Especially when you run out of material and need more, you may need to adjust some of the parameters again.
    Good luck.
  10. The Following User Says Thank You to A_Camera For This Useful Post:
  11. #9
    very useful thanks
  12. #10
    Do you have any dust extractor? In my opinion that is VERY important.
    The smallest bit I am using is a 0.5mm but it is a dual flute. Feed rate is EXTREMELY critical, run it just a tiny bit faster and it snaps. But... if you are engraving for LED signs then V-bits are better unless you need to engrave large letters or remove a lot of material, because those are more rigid. Never the less, if you run it too fast or too deep you will snap off the tip, especially the tiny 10degree 0.1mm are very sensitive.
  1. Acrylic Cutting Help
    By Tenson in forum Machine Discussion
    Last Post: 08-11-2016, 08:15 PM
  2. My Engraving and Micro-Machining Solution
    By magicniner in forum Machine Discussion
    Last Post: 16-04-2016, 07:19 PM
  3. Acrylic or mdf I can cnc
    By rainboweyes in forum Opportunities Available & Sought
    Last Post: 19-02-2013, 02:09 AM
  4. Which end mill to level my acrylic bed?
    By HankMcSpank in forum Tool & Tooling Technology
    Last Post: 03-02-2012, 02:57 PM
  5. Acrylic suppliers
    By Web Goblin in forum General Discussion
    Last Post: 24-10-2011, 09:11 PM
