  1. #35
    fifa's Avatar
    Lives in bristol, United Kingdom. Last Activity: 26-11-2017 Has been a member for 8-9 years. Has a total post count of 31. Received thanks 3 times, giving thanks to others 0 times.
    No, every ball-nut allow
    angular misalignment, and ballnut is not designed to support radial loads.
    You shall not drive screw up to critical speed, 70% limit is recommended, this is due straightness tolerances (screw is not ideally straight)...
    2010 robust, however, I would say for such type of machine too big. You will not be able to work with high speeds. Frame is too flexible.
    I am assuming you are from Netherlands, threrefore German language shall not be an issue:
    Check this site:
    Search for Minerlaguss...
    kr
  1. Triangular gantry design - opinions wanted
    By andrew 2000 in forum Gantry/Router Machines & Building
    Last Post: 18-10-2017, 10:40 PM
  2. Initial Design Check Please
    By Gotty101 in forum Gantry/Router Machines & Building
    Last Post: 28-02-2017, 07:53 PM
  3. BUILD LOG: Small rigid router - Design advise needed
    By mitchejc in forum DIY Router Build Logs
    Last Post: 17-06-2015, 08:12 AM
  4. Newbie design need advise
    By mogu in forum Gantry/Router Machines & Building
    Last Post: 15-07-2014, 04:52 PM
  5. Help wanted design laser X-axis
    By gavztheouch in forum Open Source Designs & Plans
    Last Post: 11-03-2013, 07:00 PM
