Thread: Initial design advise wanted
Haha it will never be cold in there 😊😊😊
I would definitly go for a layer of wood on the inside of the wall... maybe drywall over it.
The wood makes mounting stuff easy...
Verstuurd vanaf mijn SM-G7102 met Tapatalk
29-08-2016 #2
Hi driftspin
Noise reduction is related to how heavy the walls are. Look up 'mass law sound reduction' for more info.
There are some basic calculations on this site:
http://www.engineeringtoolbox.com/so...ls-d_1409.html
Let's say with the cnc machine running noise levels inside the workshop are 90dB. If the surrounding urban noise levels near the workshop are 50dB (with the machine off) then you need to achieve 40dB reduction.
With concrete at 2300kg/m3 and 0.2m thick this gives surface mass of 460 kg/m2. This gives an average noise reduction of 52dB, which would be enough.
With wood at 400kg/m2 and 0.044m thick this gives surface mass of 17.6 kg/m2. This gives and average noise reduction 28dB, which is not enough on its own.
Assuming you are stuck with wood, this can be improved by adding another wall with an air gap in between. Using the air gap you get more noise reduction than if you just stuck the walls back-to-back with each other - but they must not touch each otherwise the vibration will pass easily from one to the other and the benefit is lost. So mount them on separate vertical studs. The larger the air gap the better the performance, but workshop space is lost.
Finally you can add absorption material in-between the walls which takes out the high frequencies (it does nothing for mid to low frequencies which is why you need the double wall first). This can be anything fluffy, so rock wool is fine.
Make sure you seal any gaps otherwise lots of the noise benefit is lost. Make sure the roof, door and window specs are considered as well (plus floor if it is just suspended wood).
Triangular gantry design - opinions wanted
By andrew 2000 in forum Gantry/Router Machines & BuildingReplies: 1Last Post: 18-10-2017, 10:40 PM -
Initial Design Check Please
By Gotty101 in forum Gantry/Router Machines & BuildingReplies: 90Last Post: 28-02-2017, 07:53 PM -
BUILD LOG: Small rigid router - Design advise needed
By mitchejc in forum DIY Router Build LogsReplies: 120Last Post: 17-06-2015, 08:12 AM -
Newbie design need advise
By mogu in forum Gantry/Router Machines & BuildingReplies: 3Last Post: 15-07-2014, 04:52 PM -
Help wanted design laser X-axis
By gavztheouch in forum Open Source Designs & PlansReplies: 12Last Post: 11-03-2013, 07:00 PM
