Thread: Initial design advise wanted
30-04-2017 #31
So i have been reading a lot in the meanwhile.
I found this calculator for critical speed.
https://www.zappautomation.co.uk/ind...culators.html#
And for comparison
http://www.thomsonbsa.com/pdf/bsa_en...og_section.pdf
With about 1500 mm between the bearings, (long axis),
And about 900 mm between the bearings, (short axis),
SFU 1610 @ +/- 1500 mm (+/- 10mm core dia* = +/- 500RPM max * 10mm pitch) = 5 mtr/min
SFU 2010 @ +/- 1500 mm (+/- 15mm core dia* = +/- 800RPM max * 10mm pitch) = 8 mtr/min
SFU 1610 @ +/- 900 mm (+/- 10mm core dia* = +/- 1400RPM * 10mm pitch) = 14 mtr/min
It looks like 2010 is a good investment for the Long axis
I made a redisign of the frame to trade off some stiffness and complexity of the gantry vs frame.
Ill post soon since steel is on the way :-)
Triangular gantry design - opinions wanted
By andrew 2000 in forum Gantry/Router Machines & BuildingReplies: 1Last Post: 18-10-2017, 10:40 PM -
Initial Design Check Please
By Gotty101 in forum Gantry/Router Machines & BuildingReplies: 90Last Post: 28-02-2017, 07:53 PM -
BUILD LOG: Small rigid router - Design advise needed
By mitchejc in forum DIY Router Build LogsReplies: 120Last Post: 17-06-2015, 08:12 AM -
Newbie design need advise
By mogu in forum Gantry/Router Machines & BuildingReplies: 3Last Post: 15-07-2014, 04:52 PM -
Help wanted design laser X-axis
By gavztheouch in forum Open Source Designs & PlansReplies: 12Last Post: 11-03-2013, 07:00 PM
