Thread: Initial design advise wanted
40mm width and 3mm thickness of the epoxy are the minimum for 20 size Hiwin rails. 5mm thickness as all around is ok. 6x6 or 8x8 steel bar welded to frame will provide nice strong cheap channel for pouring in the epoxy. If not a continuous weld, then prime all well to check for leaks. Then pour on second step.
Triangular gantry design - opinions wanted
By andrew 2000 in forum Gantry/Router Machines & BuildingReplies: 1Last Post: 18-10-2017, 10:40 PM -
Initial Design Check Please
By Gotty101 in forum Gantry/Router Machines & BuildingReplies: 90Last Post: 28-02-2017, 07:53 PM -
BUILD LOG: Small rigid router - Design advise needed
By mitchejc in forum DIY Router Build LogsReplies: 120Last Post: 17-06-2015, 08:12 AM -
Newbie design need advise
By mogu in forum Gantry/Router Machines & BuildingReplies: 3Last Post: 15-07-2014, 04:52 PM -
Help wanted design laser X-axis
By gavztheouch in forum Open Source Designs & PlansReplies: 12Last Post: 11-03-2013, 07:00 PM
