Yes, you are right, but it also depends on the aim. If the aim is learning then almost any machine can be used, as long as the spindle can handle it. Speed may not be high and tool wear may be larger than you wish for, but the job will be done and the user will learn. But sure, some cheap machines may be far too weak for any decent job.
Yes, definitely. If he aims at selling products it is wrong to start with a cheap and bad quality tool. But he said "I'd like to develop my knowledge and skills and learn how to cut/make MDF crafts" and for that, he may not need the very best and most expensive machine.
08-09-2016 #2
This highlights another point I missed.? Your sweet spot will still be bitter sweet and the machine will be working flatout just to achive mediocre work/performance. Anything that is working at or above it's limits will fail or wear away much sooner than machine correctly designed and spec'd for the Job.
100% agree for the purpose of learning. I've always said they are great learning tool.
However and again in my experience with dealing with others the learning curve isn't any where near that new users expect. IME People have lot more potential for learning than they realise, Esp the Older generation.
So what happens is they Buy the Cheap but Limited learning machine only to realise in just few months or even weeks they have out grown the machine. End result is wasted time and money.
Also this is just looking at the BEST OUTCOME scenario. Often because they have bought cheap machine it's riddled with inferior complexity's and plagued with break downs. This results in there first Cnc experience being nightmare or less than enjoyable when really it doesn't need to be.!
I didn't Say best or expensive. I said buy machine with "Resonable Build Quality". Yes it will cost more but doesn't need to Most Expensive Machien.
On the Craft side of things it makes no difference. There's lower limit and which point the quality suffers and the correction work increases.
IME Cheap inferior machines CANNOT reach this lower limit and result the quality and work required for correction defeats the point of using CNC.
And that's without getting into Excess tool and machine wear.!!
Buying for learning is great but IMO the money is better spent on decent machine and just Commit to the task with being determined to make it work. It's not rocket science or difficult to operate CNC machine.! . . . There's enough Muppets on here manage it Ok and that Includes Me. .
Home forging
By JayWizz in forum General DiscussionReplies: 6Last Post: 04-04-2016, 01:30 PM -
Hmm - is it unrealistic to use feed/speed calculators on home built machines?
By Wal in forum Metalwork DiscussionReplies: 12Last Post: 01-02-2016, 09:53 AM -
Home is where the part is?
By HankMcSpank in forum Machine DiscussionReplies: 4Last Post: 15-07-2013, 09:58 AM -
WANTED: home built cnc
By japcarmaniac in forum Items WantedReplies: 1Last Post: 24-04-2013, 02:35 AM -
value of home switches
By engineshed in forum General ElectronicsReplies: 3Last Post: 04-04-2012, 12:01 AM
