Thread: Thread sealer.
    Wal's Avatar
    Yep, after a bit of research I decided to go with pressure - you can de-gas your mixed epoxy prior to pouring it (and that's probably best practice) but you'll end up pouring through the bubbles that accumulate on the surface and you'll likely introduce more bubbles whilst distributing and prodding the epoxy into the harder to reach areas. I can get a pretty bubble free mix by leaving the resin/hardener standing in advance and then taking care not to 'whisk' whilst mixing - you just need to go really steady with it. By allowing the epoxy to cure under pressure, you'll hopefully squeeze down any left-over bubbles - in theory 4 BAR should give a 4x reduction in volume of a given bubble.
    I bought my epoxies from Cookson Gold, you'll need:
    Hardener
    Resin
    Colour pastes
    You've also got the small quantity pearlescent effect colours - they come in pots the same size as the pastes, but they're resins and need to be mixed directly 2:1 with the hardener. In addition, a small set of digital scales and loads of latex gloves will help. Like most epoxies, it's nasty stuff so take care with it..!
    Wal.
    Wal you can buy small syringes 2mand 10m from Coronation St. Reddish http://www.lewis-plast.co.uk/diagnos...sable-syringes near you I use them when I mix very small amounts of epoxy.
    A bit late to chime in, but normally for this job i use epoxy. My vacuum station is all sealed with epoxy, so is my compressor and mist system. If i am in doubt that will have to unscrew it later, i use the 2euro epoxy from a chinese shop. Which works well. if propane or oil is involved, i use expensive epoxy.
    As a friend said once- " all you need is one hand distance aways from you, just look around, you have it"
    Also i think the double syringe item shown will mix the epoxy in the nozzle so no air entrainment ?
    Mike
    Wal's Avatar
    That friend wasn't Eric Cantona, was it..?
    Those double syringes are cool, but mixing the resin/hardener/colour paste requires odd quantities and furthermore they need measuring out by weight, ie. 10g of resin + 0.5g + 5g hardener. Might be worth trying a syringe to dispense into the more detailed parts, although I have a feeling that the mixture will be a little too viscous... On the smaller stuff I'm currently over-pouring and then sanding back the excess before polishing which gives a nice flush finish, but I do like the way that the epoxy 'sags' into the pockets on larger designs - you get some nice reflections.
    Wal.
  1. inspiration thread
    By kingcreaky in forum General Discussion
    Last Post: 21-01-2016, 03:08 PM
  2. Thread Tapping?
    By Tenson in forum Tool & Tooling Technology
    Last Post: 04-05-2012, 04:51 PM
  3. Thread diameter
    By Daniel in forum General Discussion
    Last Post: 23-02-2012, 06:18 PM
  4. Not Just another Boxford tcl 125 thread....
    By cooliced in forum Boxford Lathes
    Last Post: 18-08-2011, 10:15 PM
  5. Pipe thread in 22 tpi???
    By Robin Hewitt in forum Machine Discussion
    Last Post: 21-09-2010, 11:19 AM
