Thread: Thread sealer.
Page 2 of 2 FirstFirst 12
    A bit late to chime in, but normally for this job i use epoxy. My vacuum station is all sealed with epoxy, so is my compressor and mist system. If i am in doubt that will have to unscrew it later, i use the 2euro epoxy from a chinese shop. Which works well. if propane or oil is involved, i use expensive epoxy.
    As a friend said once- " all you need is one hand distance aways from you, just look around, you have it"
    mekanik's Avatar
    Lives in Barrow in Furness, United Kingdom. Last Activity: 10 Hours Ago Has a total post count of 807. Received thanks 101 times, giving thanks to others 176 times.
    Also i think the double syringe item shown will mix the epoxy in the nozzle so no air entrainment ?
    Mike
    Wal's Avatar
    That friend wasn't Eric Cantona, was it..?
    Those double syringes are cool, but mixing the resin/hardener/colour paste requires odd quantities and furthermore they need measuring out by weight, ie. 10g of resin + 0.5g + 5g hardener. Might be worth trying a syringe to dispense into the more detailed parts, although I have a feeling that the mixture will be a little too viscous... On the smaller stuff I'm currently over-pouring and then sanding back the excess before polishing which gives a nice flush finish, but I do like the way that the epoxy 'sags' into the pockets on larger designs - you get some nice reflections.
    Wal.
  1. inspiration thread
    By kingcreaky in forum General Discussion
    Last Post: 21-01-2016, 03:08 PM
  2. Thread Tapping?
    By Tenson in forum Tool & Tooling Technology
    Last Post: 04-05-2012, 04:51 PM
  3. Thread diameter
    By Daniel in forum General Discussion
    Last Post: 23-02-2012, 06:18 PM
  4. Not Just another Boxford tcl 125 thread....
    By cooliced in forum Boxford Lathes
    Last Post: 18-08-2011, 10:15 PM
  5. Pipe thread in 22 tpi???
    By Robin Hewitt in forum Machine Discussion
    Last Post: 21-09-2010, 11:19 AM
