Thread: Finished. DIY CNC
06-05-2018 #9
So i am about to upgrade the machine with the combination of epoxy granite and concrete in a hope to eliminate vibrations and damping and hopefully have even better cutting performance. I got high quality epoxy granite Rampf Epument 140/8b, but i have only 100kg of it so to gain more weight of the frame, i will use concrete too. I would like to hear opinions if this would work. On the picture attached you can see how i will do this. Blue color shows where i wont use EG(have only 100kg), dark shows tubes filled with EG and gray is concrete (beton). I will also fill the gaps on gantry with EG and put the EG under the table. Will this work?
BUILD LOG: Finished builds picture menu
By routercnc in forum DIY Router Build LogsReplies: 9Last Post: 05-12-2021, 12:28 PM -
Drill / Tap Guide Jig - Finished!
By Wal in forum Metalwork Project ShowcaseReplies: 10Last Post: 04-12-2014, 09:59 PM
