28-08-2016 #10
There is one HUGE disadvantage with using 0-10V, at least with the BoB's I have, is that if Mach3 is not fired up and the BoB is getting power then it will output 10V and random states for the digital outputs. This creates a dangerous situation since the spindle can start spinning when your hands are too near. This situation can never happen if you use Modbus.
I agree, this is another major advantage of using Modbus, and I will cover that in my next video. I am reading parameters like Output voltage, current, torque, power, temperature, real RPM, RPM stable... and there are plenty more, but to read those and have some use for them you also need to modify Mach3 screens used, otherwise you won't be able to see those. I have just started with this, so I am no expert, but used Screen4, which can be downloaded from Mach. I find it pretty buggy, crashes fairly often, so frequent backup of the changes is really important, but it is free, so why complain? In any case, to make modifications to existing screens is pretty simple.
Yes, I would also prefer a decent manual, but that is hardly going to happen now that Mach3 is dead. The Brains territory is even less documented than the rest. I managed to gather quite a bit of documentation spread around on the Internet about Mach3 macro programming, use and parameters, as well as about some other bits and pieces, but very little about Brains, so that is not really like skiing off-piste, more like skiing off-piste uphill. Yes, the best I could find was also Youtube video, but unfortunately not enough to help me, so I made my own. I don't know if I will write some kind of user documentation later on, because it takes quite a lot of time, but at least I will document my workflow which can be use by others to figure out what to do and how to solve their problems.
Supercomputer models one second of human brain activity
By Lee Roberts in forum General ComputingReplies: 8Last Post: 20-01-2014, 05:31 PM -
Mach3 digitizing wizard not saving file
By dudz in forum Probing, Digitizing & ScaningReplies: 0Last Post: 08-09-2013, 09:48 PM -
File upload problems - attachments file extension support !
By Swarfing in forum General DiscussionReplies: 14Last Post: 08-03-2013, 02:37 PM -
HID interface for remote control of Mach3
By Smiler in forum Electronic Project BuildingReplies: 0Last Post: 10-05-2009, 12:59 PM
