09-02-2019 #14
Hi, I have a Bosch Rexroth EFC 5610 VFD with all the manuals. I couldn't see anywhere, which terminals you used on the actual VFD itself. Could tell me what terminals you used or direct me to the manual where I can find correct information on how to configure the VFD?
I have recently replaced all the motion control gear on my router table and so far so good. I have fully calibrated motion and just configured it with an xbox360 controller.
I really would like to have the ability to monitor and control my spindle settings within Mach3.
I am using the '2010 screenset' on Mach3 to control my machine and have used 'Screen4' in the past, to modify various screens in mach etc.
I have a USB to RS485 dongle setup and showing up as 'COM4' on my windows 7 machine. My EFC5610 is already setup and controlling a 3ph 5.5kv max. 17,400RPM Perske spindle.
I have been reading through your posts on the subject on various forums and I just wanted to ask your advise now as I'm just about to start? After all you did, what is the best way to go about setting this up from start to finish?
Would it be helpful if you sent me copies of your Mach3 brain file and the Modbus configuration file with a workflow? I was thinking that I'd have many of the same parameters as you, between Mach and the Rexroth VFD.
Any help will be much appreciated!
Regards!
Darren
Supercomputer models one second of human brain activity
By Lee Roberts in forum General ComputingReplies: 8Last Post: 20-01-2014, 05:31 PM -
Mach3 digitizing wizard not saving file
By dudz in forum Probing, Digitizing & ScaningReplies: 0Last Post: 08-09-2013, 09:48 PM -
File upload problems - attachments file extension support !
By Swarfing in forum General DiscussionReplies: 14Last Post: 08-03-2013, 02:37 PM -
HID interface for remote control of Mach3
By Smiler in forum Electronic Project BuildingReplies: 0Last Post: 10-05-2009, 12:59 PM
