    Rob's Avatar
    Lives in Glasgow, United Kingdom. Last Activity: 05-11-2017 Has been a member for 9-10 years. Has a total post count of 22. Received thanks 1 times, giving thanks to others 1 times.
    Here is the basic time-line leading to my question... I had an idea to make some things but I knew very little of machining. Did tons of study and realised I will never know enough but didn't give up (stupidly or not I don't know yet). Decided CNC was most in line with what I wanted to do and got some quotes for others to prototype and produce my designs but that didn't work out. After much searching (and begging for loans) I bought a refurbished Orac cnc converted to Mach3 with a home-made auto tool changer. Learning curve (everything) so steep I wanted to just jump off a cliff so many times but stubbornly carried on.
    After many trials and tribulations such as needing to change the foreign language half-broken laptop computer it came with and stuff that I won't mention because I know how stupid it will make me look (oh, you have to twist the EM button to reset it?) I have got to the point of manually using the keyboard to jog the tools to make some things. Not the way it was intended, but I have at least now made something and know a lot more about Mach3 and the lathe. Still long way to go with the 2d/cad/cam stuff. Thinking I'll just use the wizards at first.
    The immediate problem is the auto tool post constantly slipping out of alignment. For plastic is was fine but lately I have been trying brass and it slips a lot. Maybe I am sometimes feeding it to fast and/or cutting to much depth at one time and this wouldn't be a problem if using the lathe as cnc? I took the changer apart and can see how a couple of set screws hold the tool post alignment gear with the axle, I don't think this is a rigid design. Also the little transformer looking motor that changes the positions is constantly heating up quite hot even though I'm not using it. So I am thinking to change the auto-changer for something else. First I thought about using a quick-change tool post but then I remembered seeing someone had an arrangement for multiple fixed tools on a plate and found out this is commonly referred to as a "gang" tool arrangement. Lots of videos on YouTube for this style of tool holding. I am only going to make small items and from what I've seen I think are non-standard (?) boring type tools that do things like external grooving/parting etc... the number of tools on the Orac could be easily enough to do what I want given the cross travel distance.
    Having said all that, does anyone have any experience using a gang tool holder/plate type set up? I see these tool holders can be made specifically to hold regular and modified boring tools directly or they are made to hold multiple ER collet chucks which in turn hold the tools. A company in the States that makes gang tool holders is Omniturn, but maybe someone knows of sources in the UK?
    Rob
    Lives in East Lothian, United Kingdom. Last Activity: 10 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 2,994. Received thanks 376 times, giving thanks to others 9 times.
    I ran some gang tooling along with a QCTP (Quick Change Tool Post) on my old connect lathe.
    I had mine setup to take three ER collets. Details of the setup can be found at http://www.machsupport.com/forum/ind...c,20153.0.html
    There are plenty videos on youtube for ideas, but the big limiting factor is X-axis travel.
    Personally, I'd see if the tool changer could be made reliable, as manually changing tools continually gets quite monotonous.
    Rob,
    Do you have photos of the tool changer.
    A lot of these did look home made even though they were made by the manufacturers. They used to have a tiny 24v DC motor and it spun to work the worm and wheel [ very crudely made] and went past centre, then reversed onto a ratchet and the motor stalled but then it dropped the voltage to around 9v ? to hold it on the pawl.
    John S -
    New user, hi all!
    Some stuff I have learnt with an emco pcturn55:
    drop mach3, use linuxcnc.
    probably your auto changer will work fine (mine does). Post pictures and i can comment more...
    gang tooling will also work fine.
    You need a milling machine to make tools for your lathe...
    cheers,
    john
    Quote Originally Posted by Billythefish View Post
    So changing controller software will fix a mechanical problem?
    Ah, but for some Linux is more of a Religion than a tool for a job, it's mystical properties, not revealed to non-initiates, can solve not just mechanical problems but also cure coughs, colds and pimples on the makewater!
    :D
    Rob's Avatar
    Hi, thx for both replies. I made a video to send to the guy who made the toolpost (youtube link below). His English is limited so I did repeat myself a few times and also I really had no proper idea what I was talking about :) Since then I started to take it apart and found I was completely wrong in that the two set bolts are in fact the ones that are used to adjust the gear position and which I have adjusted numerous times now. It works for a while then slips.
    The motor voltage drop would explain how they solved the tool from bouncing up and down, I was wondering about that if the belt would hold it with tension from the motor. The motor is also getting very hot though which worries me.
    Anyway, the video still shows the changer quite well so please have a look and let me know what you guys think. I'm pretty sure he did make it himself and well done to him, but I just don't know what to do to about this slipping. Plus the motor is getting very hot.
    https://youtu.be/mpLcjtrQ3pA
    Rob
    PS: I haven't got to the point of using the Orac with g-code yet, only using the manual jogging. I'm hoping to ask a friend who used to work with cnc lathes to explain the basic Mach3 turning wizards to me when possible as the cad/cam process is a bit daunting right now. I can't even understand (yet) how the different types of homing works. I'll get there eventually.
    As much as an auto tool changer is a nice idea, I still like the idea of a gang tooling arrangment. Also, this man, (maybe the forum knows him) made a really nice tool post https://www.youtube.com/watch?v=IfYLgENFvIk
    Rob,
    Won't get a chance to reply in full until tonight but once the bolts are adjusted you really need to cross drill it and fit a dowel to stop the slipping. Also make two decent thick washers up instead of the off the shelf punched out ones that will never tighten correctly.
    It looks to be reasonable made but the direct belt drive frightens me. It really needs to go thru a worm drive so it can't drive back.
    Something like this.
    John S -
    Rob's Avatar
    Thanks for having a look John. I was also thinking to drill it through and put in a dowel pin, but long term if more tools are added it might end up needing lots of holes. Actually I might do that in the short term until I can get a gang tool arrangement. I dont even see how the individual tool height can be adjusted without using shims or something. I just don't like this thing, such a hurdle and I haven't even got to the cnc part yet, rofl.
  1. Interesting story
    By TonyD in forum General Discussion
    Last Post: 12-06-2014, 09:46 PM
  2. Anyone had experience with one of these Coolubricators...
    By Wal in forum Swarf & Chip Management
    Last Post: 06-04-2014, 02:16 PM
  3. Gang Tooling Block
    By Dave Clayton in forum Machine Discussion
    Last Post: 21-10-2011, 09:52 AM
  4. XYZ Proturn SLX355 I want to Fit Gang Tooling Help!!!
    By Dave Clayton in forum Lathes, Lathe Rebuilding & Conversions
    Last Post: 21-10-2011, 08:17 AM
  5. NEW MEMBER: Hi. I'm new to CNC with a story of hope!
    By cuttingaxe in forum New Member Introductions
    Last Post: 17-08-2009, 03:59 PM
