Thread: Magnetic Fixings & buffers
28-08-2016 #2
Use a sheet of thin steel and an activated cyanoacrylate to hold your work to it, when you've done use a blowlamp on the underside of the thin sheet to release it without damaging the work, any remaining adhesive can be cleaned off with acetone.
This is how I use my mag table with jobs requiring a sacrificial layer, spacers don't work well with a holding force which is subject to an inverse square law ;-)You think that's too expensive? You're not a Model Engineer are you? :D
BUILD LOG: Magnetic slide of Z-axis
By Constantine in forum DIY Router Build LogsReplies: 4Last Post: 08-11-2009, 08:56 PM
