  1. Check this out if you haven't already- shapertools.com
    Doddy's Avatar
    Lives in Preston, United Kingdom. Last Activity: 4 Weeks Ago Has been a member for 9-10 years. Has a total post count of 1,364. Received thanks 188 times, giving thanks to others 66 times. Referred 1 members to the community.
    That's pretty interesting (the cynic in me is screaming "how much are the tapes") but really good, innovative idea. If it works, the market will be flooded with chinese knock-offs within the year.
    Quote Originally Posted by JoeHarris View Post
    I saw this about two years ago and was quite amazed but it was only 2 axis then. I can see limitations though for instance it has the limitation that it has to have the tape all around the part you are cutting therefore you won't be able to cut say within 150mm of an edge of ply. But good idea in general and I can see some good applications for it.
    Edit Doddy The tape price is on the website
  4. The tape is a pain and clearly only suitable for 2d / pocketing in soft material but I still think it's a cracking idea! So small but no real limit on the size of sheet you can cut.
  1. Hand held laser cutter
    By Robin Hewitt in forum Tool & Tooling Technology
    Last Post: 24-10-2013, 06:05 PM
  2. Replies: 12
    Last Post: 25-05-2013, 12:41 AM
  3. MIT Students Hand Held CNC Router
    By mekanik in forum Marketplace Discussion
    Last Post: 26-09-2012, 12:49 PM
  4. NEW MEMBER: want buy new or second hand cnc
    By buildwood in forum New Member Introductions
    Last Post: 20-10-2011, 05:36 PM
  5. Convert Wood Lathe from hand held tooling
    By Wobblybootie in forum Milling Machines, Builds & Conversions
    Last Post: 14-02-2010, 11:53 AM
