Thread: Hand held CNC router?!
28-08-2016 #1
29-08-2016 #2
That's pretty interesting (the cynic in me is screaming "how much are the tapes") but really good, innovative idea. If it works, the market will be flooded with chinese knock-offs within the year.
I saw this about two years ago and was quite amazed but it was only 2 axis then. I can see limitations though for instance it has the limitation that it has to have the tape all around the part you are cutting therefore you won't be able to cut say within 150mm of an edge of ply. But good idea in general and I can see some good applications for it.
Edit Doddy The tape price is on the websiteLast edited by Clive S; 29-08-2016 at 09:32 AM.
29-08-2016 #4
The tape is a pain and clearly only suitable for 2d / pocketing in soft material but I still think it's a cracking idea! So small but no real limit on the size of sheet you can cut.
Hand held laser cutter
By Robin Hewitt in forum Tool & Tooling TechnologyReplies: 9Last Post: 24-10-2013, 06:05 PM -
5-axis Breakout Includes Hand-Held Control Port & 3,4,5-axis Postion-Display Port
By LoveLearn in forum General ElectronicsReplies: 12Last Post: 25-05-2013, 12:41 AM -
MIT Students Hand Held CNC Router
By mekanik in forum Marketplace DiscussionReplies: 1Last Post: 26-09-2012, 12:49 PM -
NEW MEMBER: want buy new or second hand cnc
By buildwood in forum New Member IntroductionsReplies: 8Last Post: 20-10-2011, 05:36 PM -
Convert Wood Lathe from hand held tooling
By Wobblybootie in forum Milling Machines, Builds & ConversionsReplies: 8Last Post: 14-02-2010, 11:53 AM
